Civill 3d many tiff files with .tfw
johnymal
(@johnymal)
Hello, I have a lot of tiff files with geoinformation did we know any method to insert them all together in AutoCAD civil 3d??ÿ
Until now I use command mapiinsert but i check one by one file.
Posted : August 17, 2020 2:15 am
firestix
(@firestix)
Do you have AutoCad Raster Design available??ÿ If not, possibly try this.?ÿ There is an option to choose a folder instead of a file.?ÿ If all of your tiffs are in one folder it may work.?ÿ
Posted : August 17, 2020 6:39 am
rover83
(@rover83)
Command MAPIINSERT will allow the user select multiple files for import using Shift+Select or Alt+Select. As long as the TFW "world" files are set up/named correctly and in the same folder, they will insert just fine.
Posted : August 17, 2020 10:03 am
