Civil 3d 2017 Line by bearing not working
(@makerofmaps)
We upgraded to 2017. I have had a couple of folks that the line by bearing command stops working in a drawing. It will allow them to enter quad, then angle, then prompts for distance when they hit enter after that it does nothing and says continuing line command. They can open a new drawing and it works again. They go back to the last drawing and it doesn't work again. I've tried audit. Any clues? This is drawing me nuts!!!
Posted : August 29, 2017 6:08 am
(@david-livingstone)
I've had that happen, and restrarting Autocad or rebooting your computer has always fixed it for me.
Posted : August 29, 2017 6:11 am
First thing I would do is restart AutoCAD. Second thing would be reboot the computer.
Posted : August 29, 2017 6:13 am
 Paul
(@paul)
makerofmaps, post: 443858, member: 9079 wrote: We upgraded to 2017. I have had a couple of folks that the line by bearing command stops working in a drawing. It will allow them to enter quad, then angle, then prompts for distance when they hit enter after that it does nothing and says continuing line command. They can open a new drawing and it works again. They go back to the last drawing and it doesn't work again. I've tried audit. Any clues? This is drawing me nuts!!!
Are you using a legacy template? Something not created in 2017, but a previous version? I haven't seen this particular issue but i know legacy templates cause all sorts of weird issues to occur.
Sent from my LG-M257 using Tapatalk
Posted : August 29, 2017 6:19 am
Jim in AZ, post: 443861, member: 249 wrote: First thing I would do is restart AutoCAD. Second thing would be reboot the computer.
If you can say:
1. Close and restart the program, and
2. Reboot the computer
Then you have a future in the lucrative and growing career of Information Technology
Posted : August 29, 2017 6:38 am
(@makerofmaps)
Paul, post: 443863, member: 624 wrote: Are you using a legacy template? Something not created in 2017, but a previous version? I haven't seen this particular issue but i know legacy templates cause all sorts of weird issues to occur.
No
Posted : August 29, 2017 7:06 am
James Fleming, post: 443866, member: 136 wrote: If you can say:
Oh
Posted : August 29, 2017 11:13 am
 Paul
(@paul)
makerofmaps, post: 443874, member: 9079 wrote: No
Ok then. Are all the updates and hot fixes installed on each computet?
Posted : August 29, 2017 12:43 pm
(@stlsurveyor)
I just had same problem. Project started from a 2016 template, converted to 2017, line by brg not work, nor turned angle not working....lame.
Posted : September 6, 2017 8:11 am
