Carlson Update: Don't do this one!
RoadBurner
(@roadburner)
I've alerted support, but thought I'd post here as well to warn others. Build 150609 has a bad bug in Survey2015. You can't label spot elevations from a TIN file now. Not sure if I can revert it back to the earlier build or not. I have work to get out the door.
Posted : June 18, 2015 6:43 pm
navaran
(@navaran)
RoadBurner, post: 323109, member: 6168 wrote: I've alerted support, but thought I'd post here as well to warn others. Build 150609 has a bad bug in Survey2015. You can't label spot elevations from a TIN file now. Not sure if I can revert it back to the earlier build or not. I have work to get out the door.
http://files.carlsonsw.com/mirror/patches/carlson2015/Carlson2015Update_icad8_x64_install_prev.exe
Posted : June 18, 2015 9:44 pm
ladd-nelson
(@ladd-nelson)
I can't replicate this behavior using Build 150609 with the spotelv and the IntelliCAD engine but I am seeing an issue with the labspot command. I have notified members of our programming team and would suggest using the Surface -- Spot Elevations -- Spot Elevation by Surface Model command if at all possible until a solution can be found.
Posted : June 18, 2015 10:17 pm
RoadBurner
(@roadburner)
Thanks. Ladd. I need to revert back since I rely on the "difference between 2 surfaces" spot elevation routine daily.
Posted : June 19, 2015 9:26 am
RoadBurner
(@roadburner)
Thanks, Naravan. That .exe doesn't seem to work. Maybe it's just for icad. Time for a complete uninstall/reinstall. TGIF 🙂
Posted : June 19, 2015 9:31 am
ladd-nelson
(@ladd-nelson)
RoadBurner, post: 323210, member: 6168 wrote: Thanks. Ladd. I need to revert back since I rely on the "difference between 2 surfaces" spot elevation routine daily.
Another option to consider would be to utilize the "Write TIN Difference" option of the Surface -- Volumes by Triangulation -- Two Triangulation Surface Volumes routine that would essentially product a "Cut/Fill" TIN:
With this TIN, you could (or should be able to) then use the aforementioned spotelv command.
Posted : June 19, 2015 9:58 am
RoadBurner
(@roadburner)
Thanks, Ladd. I had made a backup of my Carlson folders a few months ago. I copied all the folders onto my HD, and I'm back in business now.
Posted : June 19, 2015 10:11 am
navaran
(@navaran)
Posted : June 20, 2015 2:11 am
navaran
(@navaran)
RoadBurner, post: 323214, member: 6168 wrote: Thanks, Naravan. That .exe doesn't seem to work. Maybe it's just for icad. Time for a complete uninstall/reinstall. TGIF 🙂
Patch for Acad:
Dropbox Logo Dropbox File (Private or Invalid)
Posted : June 20, 2015 2:18 am
