Software, CAD & Mapping
3
Posts
3
Users
0
Reactions
750
Views
I have a dwg that contains a surface mesh that's metric. I want to use it in Carlson but we obviously use feet. Has anyone of you converted a metric mesh surface to feet? Please help
Posted : June 15, 2012 2:03 pm
I've never used surface meshes, but when you are importing the surface mesh can you input a scale factor? I would think that could work.
Posted : June 15, 2012 3:20 pm
Depending on your version of Carlson, the Edit -- Scale command(s) ought to do the trick. Newer versions of Carlson have the Scale Wizard command:
If the entity truly is a mesh, you might need to explode the mesh to 3D faces before proceeding.
Posted : June 16, 2012 7:21 am
