Carlson Layers
1 Users
whitey1371
(@whitey1371)
This is a question for all of you Carlson gurus. I have a standard drawing that I open up and do a save as to start a new drawing that has all of my layers with associated linetypes and colors. I do a lot of work for an engineering company that likes for me to place all of the entities onto their layers. Not a huge issue because there is usually only a handful of layers (20-25) that I use and have to change over for every drawing. My typical process begins with me drafting the survey up in my dwg and then doing a save as and adding some name to the end of the dwg name to let me know that this is the dwg to send to the engineer. I then purge my drawing of all unused layers and then insert their layers. I then open up the layer manager and delete each of my layers one at a time placing them on the engineering companies layers. It can be time consuming. Is there a program, similar to field to finish, that I can setup with my layers and their layers that I could run that would make the last step quicker?
Posted : June 30, 2023 1:24 pm
