Carlson CR2
Jocelyn
(@jocelyn)
Can someopne tell me if this a good choice for a Robotic Total Station ? Or do you have a better suggestion ?
Posted : March 25, 2013 2:33 pm
Ralph Perez
(@ralph-perez)
Use the search function, it's been discussed at length before.
Posted : March 25, 2013 4:04 pm
cptdent
(@cptdent)
If it's Carlson and fits your budget, you will not be disappointed. That's pretty much true for most all of the Carlson products.
Posted : March 25, 2013 5:27 pm
surveythemark
(@surveythemark)
The Carlsn CR2 is a repackaged Leica TPS1200. Leica is a solid product but I am not sure what has been limited to Carlson by Leica as far as letting them repackage the TPS1200. Do you have a spec sheet for the CR2?
Also, I am not sure how Carlson will service a repackaged TPS1200 if needed. I would imagine it has to go back to a Leica Service Center somehow.
Posted : March 25, 2013 6:16 pm
Jocelyn
(@jocelyn)
I have the spec,; thanks for helping me.
Angle Measurements (Hz, V) Accuracy (ISO 17123-3) 2” (0.6 mgon)
Method Absolute, continuous, diametrical
Compensation Quadruple axis
Display resolution 0.1” (0.1 mgon)
Distance Measurements Prism (range, accuracy) 3,500 m (12,000 ft), 1 mm +
1.5 ppm
Prism, long-range (range, accuracy) 10,000 m (33,000 ft), 5 mm +
2 ppm
Non-prism (range, accuracy) 1,000 m (3,300 ft), 2 mm +
2 ppm
Laser dot size (non-prism) 7 mm x 10 mm at 30 m, 8 mm x 20 mm at 50 m
Motorisation Rotating speed 45° (50 gon)/s
AIM360 Range (round / 360° prism) 1,000 / 800 m (3,300 / 2,600 ft)
Accuracy (ISO 17123-3) 1” (0.3 mgon)
TRACK360 Range (round / 360° prism) 800 / 600 m (2,600 / 2,000 ft)
Speed 5 m/s at 20 m, 25 m/s at 100 m
SCOUT360 (Zoom80R) Range 300 m (1,000 ft)
Typical search time 5 - 10 sec
Search area Default Hz: 360°, V: 36°, definable search window
NavLight
Working range 5 - 150 m (15 to 500 ft)
Positioning accuracy 5 cm at 100 m (2” at 330 ft)
Keyboard and Display
Display ¼ VGA colour LCD, touch screen
Keyboard 34 keys including 12 function keys, illumination
Data Storage and Interface
Memory / storage Removable CompactFlash card
Interface Bluetooth® wireless technology, RS232, ZRT80 radio modem
Weight and Environmental Conditions Weight 5.5 kg (total station fully equipped)
Operating temperature -20° to +50°C (-4° to +122°F)
Protection against water and dust IP54, 95 % non-condensing
Power Management
Battery Removable Li-Ion 7.4V, 4.4 Ah
Operating time 8 h
I have the spec,;
Posted : March 25, 2013 6:34 pm
