Carlson 2016 with Intellicad 8.1
adam
 adam
(@adam)
Carlson survey 2016 has crashed on me several times in several minutes. I was in the process of erasing points by point group when it gives the warning "Intellicad has stopped working". I had the same issue with 2014 and hoped it would have been corrected in 2016. The coordinate file contains about 5000 points. The groups with 100 or so points will erase fine, I think its the larger groups that is giving Carlson trouble. I want to use the point group function but it needs work.
Posted : January 18, 2016 7:01 am
erwsdot
(@erwsdot)
Would it be better to wait to get IntelliCAD Carlson, when Windows 10 has been out a little longer. Is anyone running it on Windows 10?
Posted : January 19, 2016 6:19 pm
adam
 adam
(@adam)
erwsdot, post: 353959, member: 6038 wrote: Would it be better to wait to get IntelliCAD Carlson, when Windows 10 has been out a little longer. Is anyone running it on Windows 10?
I just installed it on windows 10 a few days ago. Seems to be run the same as it did on Win8.
Posted : January 19, 2016 7:03 pm
ladd-nelson
(@ladd-nelson)
Adam, post: 353670, member: 8900 wrote: Carlson survey 2016 has crashed on me several times in several minutes. I was in the process of erasing points by point group when it gives the warning "Intellicad has stopped working". I had the same issue with 2014 and hoped it would have been corrected in 2016. The coordinate file contains about 5000 points. The groups with 100 or so points will erase fine, I think its the larger groups that is giving Carlson trouble. I want to use the point group function but it needs work.
If you'd care to send me your *.CRD and *.GRP file(s) and the sequence of steps that you followed or group(s) you attempted to erase, I'll be happy to see if I can replicate the problem.
lnelsonATcarlsonswDOTcom
Posted : January 19, 2016 7:10 pm
adam
 adam
(@adam)
Thanks Ladd, I will send it tomorrow.
Posted : January 19, 2016 7:46 pm
