Software, CAD & Mapping
5
Posts
4
Users
0
Reactions
970
Views
Is there a simple way to edit or add to a curve label for
recorded arc distances or other curve components?
It does not appear this is possible through the
Text and Mtext boxes?
Posted : January 8, 2014 2:00 pm
In 2013 you can do it under Annotate, Annotate Arc, Edit text on Arc or Tangent.
Posted : January 8, 2014 2:26 pm
Use Edit Pulldown, Then Select Text/Edit Text
You can also edit a "BarScale" that way.
Each line of line/curve data table has multiple editable texts.
Simple to add to the end.
You can move boxes and insert a new box in the middle.
But renumbering lines/curves requires patience as I recall.
Posted : January 8, 2014 2:30 pm
THANKS!!!
Posted : January 9, 2014 10:23 am
In 2012 you have to explode the table then it's editable, but not much else afterwards.
Posted : January 9, 2014 11:01 am
