I recently cross graded to the embedded version of Carlson and noticed that the LENGTHEN command is missing. I know that this is a stripped down version of AutoCAD, but was wondering if it has been replaced with another command or other work around. I use the dynamic, delta and total length version of this command often.
Thanks Kelly
Posted : May 2, 2013 5:38 am
Looks like you can lengthen a line after selecting it and then hovering over the end point grip.
Posted : May 2, 2013 6:19 am
Try:extender
Posted : May 2, 2013 7:47 am
extender is what you're looking for. Very handy
Posted : May 2, 2013 2:26 pm
Yep ..looks like that will work great for lines. I found another command under edit for arcs. Thanks
Posted : May 3, 2013 4:46 am
