Carlson 2008 Selection variable
jimmy-cleveland
(@jimmy-cleveland)
I am using Carlson 2008 Standalone, and for some reason, I cannot select multiple entities for moving, changing properties, etc.
Is there a variable that controls the number of entities that can be selected?
Thanks in advance
EDIT:
I think I found it. I changed the value for Pickadd. This seems to have fixed it.
Is there a list of the variable, and what they control?
Posted : April 29, 2013 6:54 pm
peter-hughes-davies
(@peter-hughes-davies)
I'm not sure of your CAD engine but if your edition has Express Tools installed "SYSVDLG" will work. If not type "SETVAR" "?" "*" should list all your current variable CAD settings.
Also, there are printed lists online if you search autocad variable list or intellicad variable list.
good luck . .
Posted : April 29, 2013 8:09 pm
jimmy-cleveland
(@jimmy-cleveland)
Thanks. I will look at that
Posted : April 29, 2013 8:58 pm
jph
 jph
(@jph)
I found it here:
Settings/AutoCAD Options/Selection(tab)/Selection modes/Use Shift to add to selection (un-check)
Posted : April 30, 2013 5:46 am
