CAD OLE Viewport
5 Users
(@spledeus)
I like OLE objects (Excel spreadsheets)
And I want to put more into my drawings.
And I want to create multiple viewports to show specific cells in my paper space.
The trouble is, when I create a little viewport, the entire OLE object shows up in paperspace - even the parts outside the viewport. They do not show up in a print preview, but it will make it difficult to draft in paperspace. Is there a super lock? Is this a problem fixed later?
autocad map 06
Posted : 24/05/2012 7:55 am
(@pin-cushion)
it only works in 07 or newer... LMFAO, I am just kidding. I could not help myself
Posted : 24/05/2012 9:05 am
(@spledeus)
it would not surprise me
but it would surprise me even less if i knew they knew about the issue and never fixed it just like all the other outstanding CAD issues that are never resolved
Posted : 24/05/2012 9:22 am
(@stephen-ward)
I'm running LDD2i and I don't see the issue. I inserted an existing excel sheet into model space using "insert", "OLE Object", "create from file" option. I was able to create multiple small viewports showing single cells in paper space without the entire sheet showing up. Perhaps they broke it in future versions or we're going about it by different methods.
Posted : 24/05/2012 10:12 am
(@spledeus)
Thanks for looking. I usually highlight the cells, copy and paste. The insert seems to be a bit more stable.
I did everything same as you, but had the same issue. Bleeding object.
Posted : 24/05/2012 10:53 am
(@stephen-ward)
Try right clicking on the OLE object once it is inserted and check "send to back" if it's already printing correctly this might make the rest of the stuff in paper space show up above it and make your drafting easier. You might also experiment with inserting the OLE's on a layer that can be turned off while you do your paper space drafting and then back on before printing.
Posted : 24/05/2012 11:05 am
(@geoff-ashworth)
You could try OLEHIDE to hide it until you need to plot. Set it to 1 to hide and 0 to display.
-G
Posted : 24/05/2012 11:11 am
(@spledeus)
i even threw a wipeout on top of the OLE, outside of the viewport. the ole shows up and the wipeout does not.
Posted : 24/05/2012 11:38 am
(@foggyidea)
Ole' your own self... i never knew you were into bullfighting...
Posted : 24/05/2012 11:41 am
