C3D Point Label Style
Charlie7708
(@charlie7708)
Does anyone know how to reduces the space in between the pt#, desc & el in a label style.?ÿ I know it must be simple but I can not get it.?ÿ I have attached a PDF of the problem.?ÿ ?ÿThanks in advance for any help!?ÿ
Have a wonderful day!
Posted : June 25, 2018 6:44 am
kevin-w-shannon
(@kevin-w-shannon)
Check your Attachment points for each component as well as the Y offset.
Mine are controlled by their attachment points. No Y offset at all. text heights 0.1"
Point # - bottom left
Elevation - middle left ( with a small x offset 0.025")
desc - top left
Good luck!
Posted : June 25, 2018 7:23 am
Charlie7708
(@charlie7708)
Thank you, Kevin!?ÿ I have the same settings you have listed above.?ÿ I really hate Cad sometimes, okay almost all the time!! ??ÿ
Posted : June 25, 2018 7:43 am
cameron-watson-pls
(@cameron-watson-pls)
I see that happen every once in a while when I'm working in a drawing I've received from someone outside of my company.?ÿ There's something jacked up with either your units or the drawing scale.?ÿ Start a new drawing from your template and import the points into it and see if it does the same thing.?ÿ
Posted : June 25, 2018 8:20 am
blitzkriegbob
(@blitzkriegbob)
For an anchor point you can choose another component. For example, you create the point number component first. Then you choose that as your anchor for the description component. I would use a X offset of 0 and a Y offset of -0.15 (assuming consistent anchor points such as middle left). Then choose the description as the anchor for the elevation component, and set your offsets the same.
Personally, I rarely use all three components. Most of my points use a label style that doesn't have any labels, and my elevation shots only have an elevation component. Use point groups that have label style overrides to quickly change the label formats. For a quick check of a point with no labels, hover over the point and you will get a popup that gives you more information than you will ever need.
Posted : June 26, 2018 6:07 pm
