BricsCAD
9 Users
GarthW
(@garthw)
Iƒ??ve searched and researched BricsCAD a bit and it seems like a solid alternative to AutoCAD. Has anyone had long term usage and or success with the software? Issues, opinions?
Thanks
Garth
Posted : December 29, 2019 5:31 pm
I've been using BricsCAD for about 4 years.?ÿ It's almost an AutoCAD clone (but with a more robust AutoLISP implementation), so if you're comfortable using bare-bones AutoCAD you should be able to use BricsCAD easily.?ÿ On the other hand, if you're used to something like C3D you'll find that BricsCAD alone won't get the job done.?ÿ There are survey-specific add-ons for BricsCAD, but I'm not familiar with them.
Posted : December 29, 2019 9:37 pm
GarthW
(@garthw)
@jim-frame
Right on. I’m starting a small company and I’m looking to save where I can. I’ve been using Microstation for 15 years but I need to be dwg transferable for most situations. I’m planning on just sitting down with the software and digging in. For most of my survey needs I’ll be 2D. I’ve looked at some of the add on apps for topo line work etc. and they look good in theory. I appreciate the feed back.
Cheers
Garth
Posted : December 29, 2019 9:43 pm
FrozenNorth
(@frozennorth)
I bought Bricscad and used it with (now defunct) Eagle Point 12 years ago when I started a surveying business.?ÿ I really liked Bricscad, but I did enough commercial/heavy construction layout that I was receiving drawings from architects and engineers that had Autodesk entities that sometimes didn't translate.?ÿ I bought Autocad in pretty short order, because the potential cost of one missed dimension or annotation that somehow didn't translate was just too high.
If I was in a line of work that didn't need to do a lot of Autodesk/Civil3D handoffs, I'd give it a look.?ÿ I remember it being faster and more nimble than Autocad.
Posted : December 29, 2019 11:10 pm
GarthW
(@garthw)
@frozennorth
Good to know. Primarily I’m gonna focus on residential boundary/spot surveys to get my company started. I have a few contacts within the title company business that I’m gonna try and emphasize at the beginning. My thoughts were that BricsCAD would be a good starting point. I appreciate the input.
Posted : December 29, 2019 11:17 pm
james-vianna
(@james-vianna)
@garthw
take a look at generalcadd.com
Posted : December 30, 2019 11:23 am
rtkman
(@rtkman)
We've used Bricscad for?ÿ several years with good results.?ÿ
As mentioned, receiving other .dwgs with proxies and other smart objects can be a pain, but for general drafting it works great.?ÿ?ÿ
If someone would create a Land Desktop type addon, it would be an awesome alternative to Civil3d.
If you do get it, look up the "pointsin" lisp to import your survey data.
Posted : December 30, 2019 12:30 pm
toivo1037
(@toivo1037)
If you don't need the survey routines, and just teh drafting, Carlson also now sells their iCad engine separate.?ÿ We have it for the draftsman, and 95% of the time it gets the job done.
Posted : December 30, 2019 2:42 pm
GarthW
(@garthw)
@toivo1037
Carlson IntelliCAD And BricsCAD are the two primary pieces of software I’m looking into..Thanks for the input
Posted : December 30, 2019 2:47 pm
Skeeter1996
(@skeeter1996)
@garthw
I've got Carlson Intellicad. Never have used Briscad. Carlson is better than LDD which I moved from because of cost and lack of support. Carlson support is the best I've ever had an opportunity to use. You could end up talking to Carlson himself.
Posted : December 30, 2019 8:21 pm
rundatline
(@rundatline)
Carlson survey with intellicad is your best option. You can't beat it for the price.
You'll have everything you need and more. There's really no need to upgrade versions for several years.
I only upgrade every year or so for the intellicad update.
Posted : December 31, 2019 11:20 am
GarthW
(@garthw)
@rundatline
I’m starting to lean that way. Is the Survey package they sell generally going to let me do most field to finish operations or did you also buy other packages?
Posted : December 31, 2019 11:35 am
GradeTek
(@gradetek)
@rundatline
Is the linework point dependent or are the lines and points separate objects?
Posted : December 31, 2019 11:38 am
rundatline
(@rundatline)
@garthw
Does it all
Posted : December 31, 2019 1:17 pm
rundatline
(@rundatline)
@gradetek
Separate is the simplest answer. There are some linking features, very customizable
Posted : December 31, 2019 1:20 pm
