Autocad viewport question
Mark Laing
(@mark-laing)
okay, I draw the lot in model space and its long sides are north and south. My paper is wider than tall. I want to move north from straight up to straight right on my paper space viewport. Not in my model space. Can I do that? How?
I'm running vanilla 2004, if that makes a difference.
Thanks
Posted : July 21, 2011 1:40 pm
Beachoss
(@beachoss)
In paper space, switch into MVIEW
then, use the command
DVIEW -
Then select all the objects you want to be at 90 degrees to vertical
and press enter/accept
Then choose TWIST
and give it a reference angle (i.e 90)
That should twist the drawing in paper space only.
Hope that helps!
Posted : July 21, 2011 2:02 pm
Steve Burkholder
(@steve-burkholder)
Dview twist is what I also use.
Posted : July 21, 2011 4:09 pm
