Okay, I am stumped on this one. I had a new workstation installed last Friday.
Previously, when I went to rotate or move an item or text, I could see where the item was going to be positioned. i.e.- When I want to move something and align it to say a property line. When I clicked on the item that I wanted to move, it would stay highlighted and I could see where the final location was going to be once I finished the move command. I am unable to do that now, so when I go to rotate or move something, I have no idea where it is going to be once I complete the command. I have gone through all the settings that I can think of and I am still not having any luck. Has anybody experienced this before and if so, what setting do I need to change? I thank you in advance for your help.
Try the settings for 'DRAGMODE' or 'RTDISPLAY'. Maybe.
Doug,
Dragmode did the trick. It needed to be set to "Auto". Much thanks for your help.
Glad, that it worked, been there, done that, but it's been a long time.
With the newer machines, it doesn't effect performance, like it once did, in the old days.
