Autocad Land Desk top for Windows 7 64bit
11 Users
dannyfhorn
(@dannyfhorn)
I had posted questions about this before, but am still having trouble getting anything that works. Someone out there must have some info about what version of autocad I need to replace my OLD autocad 14 & softdesk 8 (that I love and know well)
I tried installing XP mode in VM, but that just don't do it. I am down to the point that I will likey have to buy a program from Autodesk before I can get going again
I have Autocad 2002 land desktop running on my old windows 2000 pro machine and that works really well. I can not install that on windows 7 by "properties, run in older windows mode" try as I might---
Posted : March 25, 2014 10:28 am
paul-d
(@paul-d)
Not sure if this will help but check out the info given here
I have used the steps outlined in the fourth post down to successfully install ldd3 on both windows 7 & 8
Posted : March 25, 2014 10:45 am
WA-ID Surveyor
(@wa-id-surveyor)
We had our old LDD installed on our WIN 7 64 bit machines through a 'virtual computer' that basically emulated an XP computer from your desktop. I imagine that's what the link posted above leads too?
While LDD worked it wasn't the same, it acted strangely and was almost unusable. Once my HD crashed I never reinstalled it, just wasn't worth it.
Posted : March 25, 2014 10:49 am
paul-d
(@paul-d)
No, no virtual machine, just a work around with UAC, folder naming, etc., that allows for the program to be installed and run on a windows 7 machine. Here is the copy & paste of what I am referencing:
Here is the process for both Vista and 7
Turn off UAC!!!!!
Create a folder C:Programs
Insert your LDD CD
Do not let it run.
Browse to the CD and Right click setup.exe and pick run as administrator
Install LDD to C:ProgramsLand Desktop 3
Make sure all paths are set to this in the install
Make sure you uninstall everything else you have installed before you
do this.
This only works with LDD 3, anything newer I've had no luck with.
I have LDD3 and C3D 2010 both working on the same PC.
Good Luck,
Robert
Posted : March 25, 2014 10:59 am
pencerules
(@pencerules)
If that doesn't work for you I might know of another option. I have Carlson Survey 2006 and Autocad 2002 running on a Windows 8 64 bit machine with no problems. The method I used you need to have access to a computer that has the programs installed and working correctly on, only to copy some folders from one machine to the other with a thumb drive of similar.
Posted : March 25, 2014 11:04 am
terry_jr
(@terry_jr)
I do not think you can do the install that you want with the version you have. You need to have the AutoCad versions that run in 64bit.
Posted : March 25, 2014 11:23 am
dannyfhorn
(@dannyfhorn)
Paul,
I am going to show how much I don't know-----
What is "UAC" and how do I turn it off?
Posted : March 25, 2014 11:36 am
paul-d
(@paul-d)
That is the user account control (the thing that pops up and asks if you want to let a program modify the computer). Video and instructions here
Posted : March 25, 2014 11:42 am
stephen-ward
(@stephen-ward)
I was able to get Land Development 2i running on top of AutoCAD 2000 on a Win7-64 machine. After much additional work I got the Express Tools working.
While it can be done, I found it to be unstable. Updates to Windows and other programs would corrupt the AutoCAD install. Once that happened the only recourse was to uninstall and reinstall AutoCAD. I had it down to an art, but when you're facing a deadline and your software tanks without warning it puts the cost of new, stable software in a different light.
After reinstalling AutoCAD 2000 and LDD2i for the umpteenth time I switched to Carlson Civil Suite 2013 running on AutoCAD 2013 and I've never regretted it.
Posted : March 25, 2014 11:55 am
chuck-beresford
(@chuck-beresford)
Don't know if this helps or not, (I had the same problem a few years ago- older software won't run on the new OS) but you can pick up a refurbished XP machine from a place like Microcenter for about $100- I did this a few years ago, bought extra ram to the max amount the old box would hold, and ran LDD on that machine. Worked like a charm and I didn't have to upgrade the software.
HTH- Chuck
Posted : March 25, 2014 11:58 am
alphasurv
(@alphasurv)
I've installed V2002 on both Windows 7 and 8 machines with no issues at all.
First I copy the entire CD onto the hard drive of the computer. Right click the install file and to run as administrator and in Windows XP service pack 3 mode then install normally.
Posted : March 25, 2014 12:00 pm
txjeff
(@txjeff)
Longbow software worked great for me.
http://www.longbowsoftware.com
Posted : March 25, 2014 12:29 pm
survey4ya
(@survey4ya)
This worked for me
http://www.draftingservices.com/blog/how-to-run-autocad-2007-in-windows-7
Posted : March 26, 2014 6:23 am
Longbow works perfect for me LDD 2006 Win 7/64. East to install no issues in 18 months of usage. B-)
Posted : March 26, 2014 7:12 am
