My text is hollowed out now when I print. What can I do to fix this?
Try the "fill" command. Should be "on."
Fill is on! Still doing it!
Thanks
Try textfill and fillmode variables set to 1?
:-S
What font are you using?
AHHH! Thanks....
Textfill=1 done the trick!
Ive never had this happen..Strange how things get changed!
New Times Roman!
Glad that worked!
I get the mysterious gremlins changing things in my ACAD once in a while. I don't know why or how it happens, but it does! :pinch:
Bryan
When's the last time you opened up a dwg that was (emailed or something) created by someone else?
That's usually when I notice some settings have changed.
THE DREADED WHEEL SPINNERS--
--I HATE WHEN THAT HAPPENS!!!
It helps to know that the good people of this board are here to help!
:clap:
Radar
Bryan
Yup, that'll do it all right. But then there are those other times . . . (cue "Twilight Zone" music.) :music:
Bryan
I had copied some hollow text from an old dreawing from 2003! And after that, all text that was bold cecame hollow!
Thanks
BLH
