Pix4D Mapper Question for large sites - Help
5 Users
stlsurveyor
(@stlsurveyor)
I flew a site yesterday that contained nearly 1650 images, which covers about a third of the overall site. I processed the mission last night and all went well, no errors. The overall orthomosaic image is 1.7 GB in size which is too large for my photo viewer software and C3D, so I attempted to save the file down to 20 MB by using InfraView 64, which when doing so trashed the quality of the ortho and makes it worthless. The output format I selected in P4D is TIFF.?ÿ
Does anyone have some experience/advice on dealing with large scale site in P4D where the output ortho can be useful??ÿ
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : February 28, 2019 8:25 am
chris-mills
(@chris-mills)
TIFF's tend to be around 10 times the size of a JPEG. If you can save as a JPEG it should be suitable for most purposes (such as acting as a backdrop to assist extraction of string data into a survey package). I'm assuming that PIX4D can now produce JPEGS. If you need to make an ortho smaller then do so at the processing stage by selecting a lower grade, rather than trying to shrink the image you have already produced. The largest we have produced was 7000 photos - at medium resolution it was fine (using Photoscan). On large areas it is unlikely that the client will need all of it at high resolution, so you could produce high resolution models of the critical areas.
Other option would be to produce the TIFFs for smaller areas, so you end up with blocks. In that case either create overlapping blocks or set the block size so you can load them up in 2x2, so you can always move off one and on to the adjacent one.
Hopefully in a couple of hours Lee G. will come up with a more sophisticated solution.
Posted : February 28, 2019 9:03 am
stlsurveyor
(@stlsurveyor)
Well...But I did find that in Infraview, under Image/ResizeResample - I decreased it by a factor of 10 and then Save As a jpeg the quality was maintained well enough for this purpose. Just wish Pix4D could do this internally. It is so frustrating that software like Pix4D doesn't really consider the end product.?ÿ
Posted : February 28, 2019 10:10 am
prairie_surveyor
(@prairie_surveyor)
You wish to reduce the resolution within Pix4D?
That's easy enough, under the DSM and Ortho menu, set the resolution to custom and enter your desired resolution for your mosaic.
Posted : February 28, 2019 10:13 am
stlsurveyor
(@stlsurveyor)
I will try that, and play with that option when we run the next phase of the mission. Large scale project in P4D are new to me. The overall site is about 725 aces and will probably be 4000-5000 pictures. I am sure it will take some time to know a good GSD. We are flying at 380 FT AGL. I will play with the numbers - sucks though that it takes P4D over two hours to process, even with my i9 10 core processor. Lots of waiting around to see if it works. What would be sweet is a slide scale that would tell you approx. output size as the change the GSD in P4D.
Posted : February 28, 2019 10:19 am
leegreen
(@leegreen)
In Pix4d you can also tile the Orthomosaic. Sounds like you have selected "Merge Tiles", un-toggle the Merge Tiles.
Posted : February 28, 2019 11:10 am
lee-d
(@lee-d)
We use SID compression, there's no loss and Civil 3D uses them with no issues. They also have a free viewer you can download.
Posted : February 28, 2019 11:38 am
