Below is just kind of a parade of comments on screwing in a light bulb.
Holy Cow: adamsurveyor, don’t you mean ‘parody’ of comments?
John1Minor2: so…..just exactly how many surveyors does it take to screw in a light bulb? Maybe I’ll google it if I can’t get a good answer here……
Larry P.: Well, it often takes 4 or 5, but I could show you how you could do it by yourself with a 2-hour training seminar. Just think: two mere hours and you can save on field crew time and have the others out there doing valuable survey work.
Keith: I’m not sure, but you really should take into account that the threading is curved and not straight or you’ll mess it all up.
John Hamilton: Actually, I think the threads are more spiral and not a simple circle
JBStahl: It doesn’t matter the precise mathematical shape, you just have to find a bulb that will fit into the socket regardless of the mathematical precision.
jwahl: You bunch of morons should leave the original bulb in the socket. It is the original bulb, and has its original markings. There is no need to take perfectly good evidence and destroy it.
J. Penry: You might think it’s the original monument in its original position, but let’s look at that ceiling and see. It appears to be a false ceiling, but I think I’ll reference out that existing bulb and tear out that ceiling and see where the old one used to be (er, does anyone got a flashlight?)
Richard Schaut: It doesn’t matter where the original light bulb once was, or even where it is now. It only matters where the owners want it to be. You must correct the description of where the light bulb now belongs due to possession.
Sam Clemons: I’m tired of dealing with light bulbs anyway. God provided us light and dark. It is up to us to appreciate what nature already provides.
Tommy Young: South of the Mason-Dixon Line, it would take one surveyor. Up North, it would take a good 20, and then it might not be done right.
Steve Adams: Gotta agree with y’all there, Tommy.
James Fleming: Apparently, a lot of surveyors practice Omphaloskepsis. Just change the light bulb and quit prattling about it.
Dave Karoly: How many surveyors does it take to change the light bulb? How many land surveyors does it take to change the light bulb?
Change the light bulb, what?
obviously the fixture was installed by a jack leg and we need to install a new fixture at the "true" location I just calculated from the light fixture instructions.
C. Eugene Kooper: The bulb on the surface is where it is, and the point of entry (the adit) simply must be within the limits of the walls themselves. Of course the below-surface rights follow all over the place but must not leave the limits of the claim
Loyal: Gene is absolutely correct. Through much research and physically crawling around inside those walls, I have found that the actual vein doesn’t follow any specific path; but it is all tied to the adit.
Angel: Oh you silly guys, always have to argue over everything. You boys crack me up. All you need is a stepladder and do it yourself. Let’s see now…..lefty loosey, righty tighty…..*crack* oops, dam* thing broke in my hand. Wendellllll
Tim Milton: Lefty-Loosey my butt….. It’s a left-handed threading with an obamabulb in it. That light was bound to go out quickly. It’s time to change the whole socket to a right-handed thread. That way we will have a much longer and more stable light that we can all see with.
Ben Purvis: Milton’s spot on!
Beer Legs: Tim, Tam, Cam, jim-jam….. the light isn’t out at all. You just can’t see because of your one-sided-blindness to the truth. Take your blinders off my friend. This existing left-hand threaded, low-energy light is the only thing that has saved us from running into the walls and destroying the whole house. This light bulb is perfectly stable and should easily last another four years at which time we can go down and buy another left-hand thread bulb without changing the whole socket.
RADU: Down Under we have to turn right-hand threaded bulbs to the left anyway.
GEORGIASURVEYOR: Low-energy riiiight… That’s all a scam generated by Al Goreya. There is no such thing as “low-energy” bulbs. You should see big-Al’s mansion, he has enough standard and halogen bulbs to light up all of Georgia.
Sicillian cowboy: The claim about Al Gore using halogen lights is proven false as shown on snopes.
Major_Gordie: So, what do you think? You think snopes is the end-all, always right source for everything? You don’t know how they get their “facts”. Maybe you can one day learn to reason and figure things out for yourself instead of blindly believing everything you read.
Gunter Chain: Actually, Low-energy light bulbs such as fluorescents are proven to save money energy and last much longer than the standard bulbs. See the following link with the appropriate charts and graphs. This is a scientific fact.
Both R Old: There are a lot more that last only a little while and then come apart when you take them out!! I just wish it didn’t take so many folks to change one!!
evelyn: First you should look at the light bulb and make sure it needs changing. If it doesn’t leave it alone, and if it does just do what it takes to change it and not get electrocuted.
Julie Immler: It takes 20 guys and a case of beer, or one woman and a step-stool……
FL/GA, PLS.: Now Julie, don’t you think that’s a little sexist? (Oh wait, SWMBO says she agrees with you)
Money Penny: Or one surveyor and a wife to tell him how to do it…..
jud: 20 liberal surveyors to debate whether the light bulb should be changed, whether the light bulb wants to change, and to get the government to set aside a million dollars to pay for it to be change……or one conservative surveyor.
Farsites: Yeah, right, like the liberals and conservatives don’t both spend as much as each other. Pork barrel spending is rampant by both parties and needs to be stopped. Turn it left, try it right, just get it installed and let’s figure out a new lighting system.
ted dura dura: I could do it myself without a ladder and in 5.3 seconds. Even though I’m 5’5”, 210 lbs, and over 60, I could jump up, unscrew the old light bulb and have the second bulb installed before coming back down. You bunch of wusses. Now if you leave it to a bunch of stupid #$^&!@@ and %$@(()+=_’s it will take 20 of them at least an hour. They think the day is one big break-time.
Wendell: watch it there bub, I don’t want to have to ban you again. I changed your racial epitaphs to symbols for now.
Holy Cow: Vat iz dis ting you call lihgt bubl? Enny tie to lihgtskware?
adamsurveyor: “C RTX’E QETXJ T XTFWJ VCMPE HAVH TXO UGDW EPTX C RTX T DAJW DWUTDF GD T IAVMWD TRECGX.” EWXXWQQWW NCVVCTUQ.
Dan B. Robison: Dang Tom that almost took me a whole minute. It would have helped if you hadn’t misspelled “vulgar” with an “E” instead of an “A”.
“I can’t stand a naked light bulb, any more than I can a rude remark or a vulgar action.” Tennessee Williams
John Giles: Well, I wrote a sonnet about it……let me get it and print it for you.
tolinghouse: Ferget those sonnits and digging in the sealins, I rote a rednecs guide for changing a light bulb, if I can only find it. Email me if you want a copy.
BigE: TY!!! How you been bro! tried to call you the other day. You know me and the crew changed a light bulb lickity split when I was surveyin’ a couple of years back. Send me a copy of your book though so I can refrence it. It reminds me about when I had a monitor go out while I was writin’ some high-end code. It made it real hard. Maybe I can write a program to change the light bulbs in the future with your guide.
Holy Cow: Ty, I think you misspelled ‘sonnets’. Using “sealins” instead of ceilings changes the whole meaning of your sentence.
(to be continued)
On screwing in a light bulb - redux continued
Carl B. Correll: 20. One to change the light bulb and the other 19 to discuss the best way to do it.
jud: 15. One to hold the light bulb and the rest to drink whiskey until the room spins.
Corey Diekman: How many surveyors on a Professional Surveyor’s board of directors does it take to change a light bulb? At least 10 to debate on whether the light bulb is out or not, and even if they agree it is out, they may not change it because it might offend some members who might not want it changed. You jerks keep reminding me of why I quit coming here....
Daryl Moistner: 3. Got some pictures at the following link.
J.W. Glidden: I came back just for this thread….. it takes 2 and a step ladder. The second guy is just for safety purposes. You guys should listen to Angel.
6th PM: Well I suppose Kent would just bump the whole light bulb over until it worked instead of installing a new one.
Kent McMillan: Dear 6:00 PM, I know you are in Colorado, and don’t quite understand electricity. I swear all of you guys up there are ESFP personality types. That’s fine, but It doesn’t make for a good surveyor. Good thing you live in PLSSia and can just look up your cookbook when you need to survey. I hope you have a good manual for changing light bulbs.
LRDay: Kent, you don’t know the first thing about the PLSS system, and that makes me doubt you can actually change a light bulb either. All you do is treat others with some superior attitude.
Scott Zelenak: If it took us this long to change the lighting at the Freedom tower, I’m afraid it would take longer to light it up than it takes to build the whole thing. Posted below are some pictures of the freedom tower at night.
DEREK G. GRAHAM OLS OLIP: You think this is confusing…..wait until Light-squared takes effect. It will eliminate the ability to use regular lights from now on.
Pablo: Only an office surveyor would even think about this.
Deral of Lawton: Frankly, I use solar-power and low-e light bulbs to light my home. It leaves a much smaller carbon footprint and I haven’t had to change a light bulb in 25 years. I’ll save my energy for the ladies….
Jim Petty: Hey De-rail, whut is this-ere carbony footprint your talking about. Why don’t you just clean yer shoes and change the dang bulb?
Nate the Surveyor: Git a couple of the kids to do it. It just takes a properly wed man and wife to make some little laborers to take care of that petty stuff. Big help can do it himself by now….and set up the GPS receiver.
Don Blameuser: You think this is bad, don’t even ask how many engineers it takes to change a light bulb.
Paul in PA: HEY!
MLSchumann: HEY!
LRDay: HEY!
Apologies to all.....:-P
That's why I like candles.
Adamsurveyor............Step away from the computer. You need a 30 day vacation at the official Beer Leg Rehab Center for addicts. You have almost become "One with the Forum". Any closer and your mind will completely melt into nothing but a generator of memories that never happened in the real world. Take heed from someone who has been there and done that. Please excuse me, now, as I must go gather the iguana eggs.
Brilliant!
We don't care how you do it up north
Wow!
You guys need to spend more time with the wife, with some soft music!
Romance is still a good way to spend the day.
Excellent.
I was reading with baited breathed both hoping for and against seeing myself in there. Pleasantly relieved. But, you've done fine. No need to improve on it. 😛
Call this a shameless rip off of "that other Larry" if you want.
But,
I don't care who you are that's funny right thar.
Thanks for sharing Tom. Hope you had a great Thanksgiving Holiday.
Larry P
Wow!
> N
And then, nine month's later back at the ranch, another "Big Help" pop's out!
Have a great weekend!
"(Oh wait, SWMBO says she agrees with you)"
Translated that means I do too. I think...hmmmmmmm
Great post and have a great weekend!
Howling with derisive laughter!
Yaa''llll be careful, in there, ya hear?
I really hate to mention it, but "screwing in a light bulb" is not the best place for such activities. They break, and cause all kinds of problems. Not to mention all the warnings that are on those things. Mercury, and poisens etc. It is possibly a conspiracy to reduce the population of the earth, to even mention such a thing. Read the lables on the next pack of bulbs you buy, and please, keep out of light bulbs. Especially for the above mentioned activites. Possibly, Kent Mc could still do it, because he is so accurate, but the rest of us, being 0.04' off could mean instant death. Some unsuspecting janitor could also flip on the switch, and then it would be all over, if you are not accurate enough. It would cull the herd though.
Please be careful. Ty Ollinghouse would get blown to smithereens if he tried.
I hear Big E is not too big, so maybe there could be some wiggle room there if he tried it though (But I don't think he's married). Just be careful. Does your insurance cover it? There is alot more that could go wrong, but I hope nobody gets hurt.
This has got to be one of the funniest posts I've read in a long time!
So Nate.....I guess your answer is that it takes two to screw in a light bulb, and that might be too many not to mention dangerous....;-)
Right, Adam, but right now, the "Concept" (No pun intended) is scaring me!
Dang, Tom
I've tried to cipher what you and Nate are saying...I keep getting stumped on the word 'NEKID'...
DDSM
(I must be a dim bulb)
LOL:beer::-D
I'll second what John said. That was brilliant.
Modified RADU:
Here in OZ the procedure is outlined in the Torrens System and can be a regular cockup if you haven't attended the seminar. You have to cut a hole in the floor above the light bulb location and reach down under to preform the task. And of course it is a lefty-tighty, righty-loosey maneuver.
Great! Glad I found this site again.
