Use of External Ant...
Use of External Antenna with Rover R8 in Heavy Vegetation Area
7 Users
MARIPOSA
(@mariposa)
hi, I have found that the radio link gets disrupted when up against tall trees/vegetation and was exploring the idea of using an external antenna on a backpack to get a little closer to the ground features I want to topo (like trees). Does someone have experience using an external antenna with the rover for this purpose? I often use the sun shot option to offset the features but wasn't sure if the external antenna might help these obstructed locations.
Posted : February 18, 2024 7:04 am
john-putnam
(@john-putnam)
If you are referring to the UHF antenna, then yes, it is possible. In fact, older units required external UHF antennas. I run an external whip antenna with my Leica kit when mounted on our UTV.
Posted : February 19, 2024 1:03 am
dewam
(@dewam)
We have found it in our interest to bring a whip antenna with 25' of cable to most jobs. It is not often used, but it sure can save a lot of time when working the the edges of reception with low topo features.
Posted : February 19, 2024 2:36 am
rover83
(@rover83)
The R8 antenna connection is compatible with the SMA connector for the whip antenna cable kit.
I used to attach the whip antenna + mast to R8 bases quite a lot. Never did it with the rover personally, but it will definitely work.
Posted : February 19, 2024 4:11 am
jimcox
(@jimcox)
If you are working around heavy vegetation, do yourself one big favour and get a modern receiver
Some the new kit out there is a whole generation better than an R-8 - and it shows up especially with canopy
They really are that much better
Posted : February 19, 2024 5:48 am
RobertUSA
(@robertusa)
Yes, when I used even a R10-1 in the trees with a R8-2 base I’d sometimes spend 10-15 minutes waiting to get a good enough fix and sometimes the elevation would be off 5 to 10 feet. Now with R12i rover and R780 base, it takes about 5 seconds. But new receivers won’t change radio reception problems.
Posted : February 19, 2024 7:02 am
MARIPOSA
(@mariposa)
Thanks for the feedback on this. Yeah I’m using the R8. So I’ll try using a zephyr antenna with gnss on rover range pole. One day I’ll be able to upgrade to the newer versions.
Posted : February 22, 2024 12:48 am
Bruce Small
(@bruce-small)
Long ago I noticed that my body could block the radio connection if I stood in the way, so I had a metal clip made that fit on top of the rover rod, just under the Leica dome. Voila - much better radio reception.
Posted : February 23, 2024 1:08 am
