Trimble DL and "rov...
Trimble DL and "rover only"
tonyduky
(@tonyduky)
Question rapide :
Puis-je utiliser Trimble DL avec un récepteur GNSS Trimble uniquement « mobile » (et non fixe) pour effectuer une longue acquisition statique (à corriger ultérieurement avec le point central de l'émetteur radio) ?
Going to a remote location without any NRTK paid subscription. I can only bring one GNSS receiver.
I wanna be able to do long statics (1h) on a few points and correct them with Trimble RTX (and later use them with a TS)
and I wanna try connecting to some free NTRIP casters that might be available there.
I know I could not use NTRIP corrections with a "base only" receiver so if i take a "rover only" receiver can i do static mode and NTRIP?
thanks a lot guys!
This topic was modified 5 months ago 2 times by tonyduky
Posted : May 6, 2026 1:25 am
stlsurveyor
(@stlsurveyor)
I would take the approach of using PPK with RTX in remote locations. Plan on a bit longer occupation times than normal, especially to start/end the day, but should be fine.  Unsure of what your definition of "remote" is, but IGS has plenty of stations around the globe you can pull data from as your base(s).  Test before you leave, compare 30 mins static OBS to PPK see what you think.
https://igs.org/data/#daily_data
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : May 7, 2026 4:29 am
tonyduky
(@tonyduky)
@stlsurveyor Yes that was exactly my plan.
I just dont know if i can do a static with a "rover only" receiver or if i need a "base" receiver for that?
(I know you can't use a "base only" receiver as a rover to do measurements for example)
If i can, then I would take a "rover only" R2 or R6 and do both static and Ntrip measurements with it.
Posted : May 7, 2026 7:21 am
jimcox
(@jimcox)
Posted by: @tonyduky
If that is not working, something is very borken in your system...
Posted : May 7, 2026 2:04 pm
