Hello everyone.?ÿ My bluetooth doesnt work on one of my SP80s so I'm trying to connect my TSC7 collector to my SP80 and Pacific Crest radio via a cables. I got a cable from Western States Cables (Brad has been super helpful). I have the TSC7 connected via 9 pin to the SP80 and the SP80 connected to the radio via limo connectors. The cable I got from Brad also powers both units. The problem is that when I try to start the base I get an error that the port is already in use. Has anyone ever used a setup like this? I'm hoping I just have a setting issue or else I'll need to send the SP80 for repairs.
Gregg
I had a similar problem with my trimble gear. I switched the port number in the data collector and all worked fine after that.?ÿ
@husker796 Thanks, I did try that. It allowed me to connect to the radio with everything hooked but it still doesnt work when I try to start the base. I'm going to try changing some settings in my survey style and see if that helps.
