Solar Panel to powe...
Solar Panel to power GNSS static receivers
stlsurveyor
(@stlsurveyor)
Looking to learn more, which to buy, how to buy, and what to learn about solar panel power. Anyone here use solar panels to power and/or charge 12v batteries?
Thus far it appears no manufactures offer such a solution through "OEM" options. Anyways, looking for info on a set-up like this. This was a post on twitter and UNAVCO re-tweeted and apparently had some input on...
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : January 9, 2020 4:48 pm
You are going to need at least a small battery to get through interruptions by shadows such as a bird landing on the panel or an animal standing nearby, unless the panel is grossly over sized.
Find the ampere draw of the receiver and pick a panel rated for that current at whatever sunlight you expect.?ÿ Whether you plan for clear or overcast days will make a huge difference in the panel rating needed.
Posted : January 9, 2020 5:24 pm
jt50
 jt50
(@jt50)
what brand is your GPS receiver? most of the new ones?ÿ that charges via USB connections?ÿ can run off cellphone powerbanks. you could get a high capacity powerbank that can literally lasts several days.
Posted : January 9, 2020 5:33 pm
