Ok .?ÿ
after much testing and anguish, it's finally been determined that the base station in Turlock .TRLK?ÿ is the culprit .?ÿ ?ÿMy system connects to the internet just fine.?ÿ ?ÿThe Carlson Surv CE indicates corrections are being received but the system remains autonomous.?ÿ ?ÿ When I switch to another CRTN base, I get a fixed solution.?ÿ ?ÿ ?ÿ Only trouble is, TRLK was the most often used base.?ÿ ?ÿMaybe Cal-Trans has an issue with this base ??ÿ?ÿ
Posted : February 23, 2019 2:38 pm
