R12i settings
11 Users
Which constellations are being used?
E8D0BCAD 12C0 40B5 951A 3CC8155630E3
Posted : May 23, 2022 9:46 pm
jitterboogie
(@jitterboogie)
Supporter
Was that a Jeopardy! Answer?????
Posted : May 23, 2022 9:58 pm
johnymal
(@johnymal)
Check them all only one of them does not work I think is the Chinese.
Posted : May 23, 2022 10:37 pm
jimcox
(@jimcox)
Select all of them
Then it depends on what your base is tracking
Posted : May 24, 2022 2:40 am
@johnymal We weƒ??re staking out to a coordinate weƒ??ve determined before. Turning on BeiDou moved the stake out from nearly flat to move 5 feet east. To be fair I didnƒ??t have it on in the base at that time. Last night I was editing the style.
The other issue is it took it a long time to download a 2 hour file with 5 second epochs over Bluetooth, far longer than the old R10 base.
Posted : May 24, 2022 5:48 am
Supporter
@dave-karoly?ÿ
It's odd that it requires more time to download. I've noticed my TDC600 is much quicker than the older DC's I've used, are you using a new DC with the R12's or the same with both receivers.?ÿ
Posted : May 24, 2022 6:35 am
Member Debater
Having Beidou turned on should not affect the results by 5 feet. What correction source are you using? If VRS, definitely not. If RTX, you need to make sure the results are being transformed correctly to NAD83 (2011) or whatever datum you are using. If not using RTK/VRS/RTX, then you might be getting WAAS corrections, which are GPS only and referenced to ITRF with a 1 meter accuracy ?ñ. Or maybe you are just autonomous, in which case 1 to 2 m or more is possible.
I typically have GPS/GLONASS/Galileo/Beidou turned on all of the time at base and rover. I turn off the SBAS satellites so that I don't inadvertently get WAAS. If using VRS, it will just use whatever is available.?ÿ
Also, MUCH easier and faster to download over wifi. I connect my smartphone or laptop to the receiver over wifi and then download to my phone or laptop. I also have the ftp server running on the receiver.?ÿ?ÿ
Posted : May 24, 2022 6:37 am
jitterboogie
(@jitterboogie)
Supporter
@dave-karoly?ÿ
Did you try the lemo to usb cable and a data stick??ÿ That should speed up that offload process.
Posted : May 24, 2022 7:14 am
Fairly new TSC5. Just updated to Android 11. Maybe thatƒ??s a mistake. The Android operating system sucks, TSC3 was far better than this. Damn thing is unresponsive, need a hammer for a stylus, just has a slightly aggravating feel. Once running in access itƒ??s okay but getting files onto the stick at the end of the day usually a lot of swearing and cussing. Have to wait for the progress bar then some indeterminate length of time after that, how stupid.
We always run our own base. No VRS.
Iƒ??ve never had a problem downloading via Bluetooth. Will have to explore other options.
Posted : May 24, 2022 8:35 pm
BStrand
(@bstrand)
Member Debater
Bluetooth is a really tiny pipeline, iirc.?ÿ I tried downloading a simple text point file over it several years ago and I think it took 20 minutes.
Posted : May 24, 2022 8:45 pm
Member Debater
The first generation Bluetooth handled 700 kbits (~ 70 kbytes/sec) and later ones are faster. There was some problem if a point file took 20 min.
Posted : May 24, 2022 9:45 pm
Posted by: @bill93
It was the GNSS observation file. Other receivers Iƒ??ve had in the past werenƒ??t that slow even though itƒ??s Bluetooth. When I was downloading it out in the field I thought maybe it was a 1 second file because the style for an RTK base defaults to that but I had already changed it to 5 second.
I wound up putting the receiver and controller in the back seat and let it download while we drove down the mountain. Iƒ??ll check into Wi-Fi as an alternative.
Mostly Iƒ??m interested in which constellations people are using, it sounds like all.
Posted : May 27, 2022 6:03 pm
RobertUSA
(@robertusa)
Beidou are the best satellites up there. The B3 set broadcast 4 signals and have the least noise in their signals.?ÿ
Also you are recording way too much data at 5s logging for a 2 hour file. If you are using OPUS, it decimates the file to every 30 seconds, though Trimble RTX post processing will use 10s, intervals. Trimble has a white paper on static baselines with recommendations on logging intervals based on the total time that will be recorded. The longer the session, the less frequent data is stored. Shorter sessions is when you record in the 1 to 5 second range.?ÿ
Posted : May 27, 2022 6:45 pm
richard-imrie
(@richard-imrie)
When we added BeiDou to our receivers, via a firmware upgrade, it also needed a language change/upgrade in the DC, without which while the receivers would be ok tracking the BeiDou signals, there would be no transmission of the corrections.
Posted : May 29, 2022 5:41 pm
GaryG
(@gary_g)
Supporter
@robertusa Could you link the white paper please ? Thanks
Posted : May 30, 2022 4:32 am
I turned everything on in the base and rover in the style.
Fired up the base in my backyard, not the best spot for a base but okay.
Fired up the rover. At first it was pretty slow, not good but after 15 minutes of getting some observations in the open it started working a lot better under my redwood trees, next to tree trunks, etc. ?ÿIt had 22 SVs at the height. At first it was only seeing 10 in the rover. The base had 17 from the start.
It seems like it needs some open sky time to download the ephemeris and find itself. After 15 minutes or so it was able to find a lot more SVs.
Posted : May 30, 2022 1:17 pm
Supporter
Since you asked this question I've downloaded an R8 and an R10 base file with the TCS600. Both took similar times and were downloaded in minutes.?ÿ
Not sure what's up with the R12/TSC5 connection but I'm guessing something must be off.?ÿ
I hate having to pull the receiver into the office for downloads. Much easier to plug in the DC and have the static files loaded on it with the day's work.?ÿ
Posted : May 30, 2022 1:37 pm
Posted by: @mightymoe
My habit is to download each file at the end of the session. That way I have all the files in the Controller at the end of the day.
The TSC3 was just a better controller but we canƒ??t use it with the newer receivers.
The TSC5 is okay but it hesitates too. Sometimes doing Topo with the S7 on track it hesitates when populating the numbers after the take a shot button push, not always, just sometimes. Half a second or a second or so but itƒ??s annoying, throws off my rhythm. The TSC3 never did that. Took me a few minutes why it was complaining about trying to store an empty shot until I noticed the hesitation.
Maybe itƒ??s my fault, I updated the Android system.
The Android file system is clunky. I copy the project folder on a USB flash drive, all the dates and times are the minute I do that, not like Windows which is the actual date and time the last time the file was saved. At least the battery life is a lot better than the TSC7.
Posted : May 30, 2022 1:50 pm
