Hi Paul or some other Rinex Guru,
Had a crew member forget to stop the GPS between static occupations on two points. I ran the whole file through TopCon Tools and it provided me with the later solution. I cut out the first 20 minutes and I obtained the first solution.
I found a note about the GPS moving, but it was at the end of the file. Perhaps it was not stopped properly.
Without trial and error, is there a way to know when the unit moved (field notes were missing time of start and stop as well.)
Thanks,
Thadd in MA
Posted : December 31, 2014 8:53 am
Attach the Rinex in a reply to the email I sent you.
Posted : December 31, 2014 9:14 am
Special Thanks to Paul in PA for the help.
Posted : January 2, 2015 8:11 am
