I find it interesting that people usually refer to the Geodetic Reference System of 1980 as merely a geometric figure. They define it in terms of its semi-major axis and flattening (usually its inverse). Yet the defining parameters shown here http://geodesyattamucc.pbworks.com/f/grs80_parameters.pdf are mostly geophysical.
This is of course due to the fact that the dimensions of the reference ellipsoid are intended to closely approximate that of the GEOID.
Note that the semi-minor axis is a derived quantity. Some GIS folks are rather cavalier with these parameters even using the semi-minor axis without consideration of significant figures.
In closing, the recent thread about reference frames and datums shows how important it is to keep track of what is what.
Well, in my job, I don't need the geophysical values, I only care about GRS80 as a geometric figure. If the geophysical values are needed to calculate some transformation parameters, etc., I hope that the appropriate scientist or geodetic agency has done so.
Not with this group, but many people won't comprehend the geophysical-related values. They can, usually, visualize or understand an ellipsoid.
I also have a problem with the published derived parameters as given. You can't convert between b (semi-minor axis) and f (flattening) and then back-calculate them with the given precision. If I try to calculate f from a and b, I don't get the stated value. If I use a and f and calculate b, I can see that b is missing .00004 which would let me reproduce the f value from a and b.
If a software package isn't coded correctly (calculating f from a and b), this can cause issues with large values, like say, state plane zones.
See #2 this link.
EFB, Unfortunately I do not have the document to which your link refers.
With respect to the issue of the incompatibility of a, b and f-inverse, I always thought that the value shown for the semi-minor axis should have been eliminated from the table. Showing it to the precision needed for use in solving for f is absurd ( that would be 6356752.31414036 ). Using truncated values for b lead sto errors in computations. Some GIS software documentation I have seen even truncated the IAG value to the millimeter.
The folks at Matlab provide this nice solution: http://www.mathworks.com/help/map/understanding-spherical-coordinates.html
I guess I was mostly agitated by the assumption of many that some of these parameters are arbitrary. It has been a long week. Typing is in an IPad doesn't help my mood any.
Thanks for that. I'd always thought of GRS80 as the ellipsoid and NAD83 as the reference frame.
I suppose this wrong thinking is supported by the fact that we treat NAD83 as the reference frame in OPUS reports with the addition of the adjustment label - NAD83_21011. I've never observed (and I'm no geodesist so it isn't surprising that I haven't observed) a transformation from IGS or ITRF to GRS80, only to NAD83.
GeeOddMike is correct that GRS80 is not merely an ellipsoid
but is a rotating, equipotential surface that is an ellipsoid.
As such, it generates not only an ellipsoidal figure, but
also a normal (that is "generic") gravity field. GRS80 can be
used to compute gravity anomalies from gravity measurements
(by subtraction of the normal field).
There are 4 defining parameters:
a =6378137.q0 semimajor axis, meters
gm =3986005.q+8 G*mass Earth, m**3/s**2
dj2 = 108263.q-8 j2 -- tide free
omega=7292115.q-11 rotation rate of Earth, rad/sec
the computation of other parameters, both geometric and
geophysical is rather exacting, and benefits from use
of quadruple precision (that is 128 bit floating point).
The iteration loop for first eccentricity squared, e2, is slowly
convergent -- and yields:
e2 = 6.694380011821693349263024628781072E-0003
e2 = 6.694380022928091730238403447816178E-0003
e2 = 6.694380022903360802879867466743127E-0003
e2 = 6.694380022903415871926288600370417E-0003
e2 = 6.694380022903415749302505441666407E-0003
e2 = 6.694380022903415749575555243028413E-0003
e2 = 6.694380022903415749574947235607143E-0003
e2 = 6.694380022903415749574948589061952E-0003
e2 = 6.694380022903415749574948586516432E-0003
e2 = 6.694380022903415749574948586143422E-0003
e2 = 6.694380022903415749574948586144959E-0003
e2 = 6.694380022903415749574948586290942E-0003
e2 = 6.694380022903415749574948586548475E-0003
e2 = 6.694380022903415749574948586457761E-0003 <<<-- answer
With e2 in our pocket, the remaining values are readily computed:
f = 3.352810681183637418165046184849002E-0003
finv = 298.257222100882711243162836600094
b = 6356752.31414034743838861704682171
E = 521854.009700354411772065745653499
c = 6399593.62586403164801394233560317
m = 3.449786003077674246389384933960420E-0003
ep2 = 6.739496775481621906223307129611649E-0003
ep = 8.209443815193342259764018499876038E-0002
q0 = 7.334625841081868876618940446801025E-0005
q0p = 2.688041313666664981318347214790298E-0003
ge = 9.78032677153489285793472943427557
gp = 9.83218636851957475228545044898622
cay = 1.931851353260676360748688677805263E-0003
u0 = 62636860.8500461186518037764982839
Note: all of these are *derived* quantities. They are
consistent among themselves, and with the defining quantities.
It is certainly true that if you truncate one or more of
these quantities, then it matters where you truncate to
keep the same truncated accuracy level. These quantities
are interrelated, and have quite different units, so it is
not safe to truncate at the same number of digits. The values
above should be accurate for all purposes.
The reference equations for this can be found in a reprint
from the "Geodesist's Handbook" :
http://www.geology.ohio-state.edu/~jekeli.1/GS6776.2013/GRS80.pdf
By the way, GRS80 is not a Reference Frame, whereas any of the
ITRF's or any of the NAD83's are. Hence, there will be transformations
between Reference Frames. There are expressions for transformations
between different ellipsoid references, but these are seldom used
in practice. One just goes from lat/long to XYZ, then back to lat/long
with the target ellipsoid.
Best wishes....
thank you
I post this ??oldie but goodie? to supplement discussion in the WGS - ITRF thread.
The particular issue was the computation of the first eccentricity squared. Here Dr Milbert shows the result of his iterative results using ??... quadruple precision (that is 128-bit floating point).?ÿ
The link to the Geodesist??s Handbook in Dr Milbert??s near six-year old post does not work. My review of recent copy??s of the Geodesist??s Handbook do not show the equations. Those here look good: http://www.mygeodesy.id.au/documents/Eccentricity%20of%20the%20Normal%20Ellipsoid.pdf
Note that the author of the linked document (R.E. Dealing) acknowledges our own Mr. Nolton??s correction to his determination of 1/f. I confess that I was unaware of the program Maxima. I don??t know if I??m up to explore another calculation tool. ?ÿ
HTH,
DMM
I see you give a link to a paper by Prof. Dr. R.E. Deakin on ECCENTRICITY OF THE NORMAL ELLIPSOID.
I don't think you have read this paper. Please read it and look at the Notes on page 3 ;
(Notes on minor corrections to original version)
Then on page 4 you will find the code that both Dr. Deakin and I used to calculate some of the parameters.
I did my calculations in 1995.
Please look at his values on page 4 (near the bottom of the page) e^2,f and 1/f; THEY ARE CORRECT
JOHN NOLTON
While I do not usually participate in pointless disputations I feel the need to address your post. I use the term “pointless” as the level of difference between the values of the first eccentricity squared (e2) provided by Milbert and Deakin is 1.7 x 10^(-31). In the Moritz paper he shows the derived value to fifteen decimal places.
I did read the Deakin paper as well as two previously linked.
As computations of the flattening (f) and its inverse (1/f) depend on e2 (and the formulas are the same in both Moritz and Deakin), I only concerned myself with the calculation of e2. Deakin usefully provides a good starting point for the iterations. As Milbert states the formula is slowing converging.
As the link provided in the post by Milbert is no longer valid, I did a search and found a similar paper Deakin. It has useful detail about the iterations needed to derive e2. A comparison of the formulas in Moritz and Deakin show them to be the same.
As you have stated that you used the code in Deakin for your calculations did you also use Maxima?
I note that the program is described on page 3 of Deakin thusly:
“Maxima is a computer algebra system that yields high precision numerical results by using exact fractions, arbitrary precision integers, and variable precision floating point numbers. http://maxima.sourceforge.net/ “.
While Milbert did not detail his computation process, I assume he used the formulas in Moritz (and in Physical Geodesy) as well a using quadruple precision in his work. I cannot explain the differences but wouldn’t quadruple precision trump “variable precision floating point numbers”? Remember I am unfamiliar with Maxima and its syntax.
As for the differences in the two results (Milbert and Deakin), they amount to 1.7 x 10^(-31). Not many tools work at that level of precision. Like the calculation of ever more precise values of pi, at what point is it useful in applied sciences like Geodesy? <this is heresy I know).
In closing, I do not know what explanatory point is served by telling me to look at his calculation results. Assertions that “THEY ARE CORRECT” shows confidence in your work (and Deakin) not much else. Making your statements in bold doesn’t make them any more convincing.
Tools available to me will not allow me to work at the precision of your results.
I thought it might be something like that. Sometimes I try to type too fast and then hit the wrong key and then I have a bad habit of not checking what I typed. Plus just being a bad speller leads to a bad post on my part.
Prof. Deakin is a friend and he is Retired (last year). I hope people interested in geodesy on this board will look at his stuff.
Hope you are feeling better
JOHN NOLTON
w?ÿ = angular velocity of the earth?ÿ as expressed in radians
what a great concept and a cool number 🙂
and being given the two equivalence sphere radii.
The three would be fun to draw and animate.
But it's still a 'pure' shape and doesn't actually model the real equipotential surface complete with its humps and hollows...
You use the word "pointless" (see your post above); well it not pointless. If you print a number then it should be correct to the number of digits printed. Would you want a logarithmic table (in the old days) to say its is 7 places but only correct to 5?
I would hope not.
In 1995 (20 Jan.) I used MACSYMA to calculate geodetic guantitys to many digits (90). I would NOT have put in print all 90 digits because of computer roundoff etc. FYI the Newton iteration package in MACSYMA was not working (had a flaw and I reported it to the company). I did use T. Vincenty's value for 1/f 298.25722210088 to start with.
Another question from you; "wouldn't quadruple precision trump "variable precision floating point numbers"
answer: NO
Final statement: my calculations in 1995, Prof. Deakin in 2019 and Dr. C.F.F. Karney circa 2011 all agree and are correct, period.
JOHN NOLTON
For those interested in Prof Deakin’s papers, many are linked here:
https://scholar.google.com/citations?user=M6keBAkAAAAJ&hl=en
Not wishing to extend this thread further, I nonetheless close my participation with the following comments:
1. Having spent some time trying to install Maxima on my MacBook (unsuccessfully) and then starting to develop a script using the equations in Mortitz’s GRS 80 paper in Matlab, renewed my appreciation for those able to wean high precision results in their computations of the derived GRS80 parameters like you and Deakin.
2. I too harshly characterized work to obtain the highest levels of precision possible as “pointless.” Perhaps I should have used the formulation in Deakin’s paper on transforming Cartesian to Geographic coordinates that appeared in the Australian Surveyor (1999) from which this excerpt is taken:
In another post on this thread I provided a link to a listing of Prof. Deakin’s papers. I enjoyed those that I read.
I consider this thread closed,
DMM
