Hello,
Here are the modules for the GNSS (GPS) class. All feed back is welcomed.
Feel free to share and to use as you see fit for all of the modules I have uploaded.
This class includes GPS fundamentals, error sources, methods of survey and a fairly detailed step by step description of Least Squares Adjustments without the matrices of partial derivatives.
https://surveyorconnect.com/community/threads/geodesy-and-gps-class.331382/page-2#post-438670&apos ;">
Thank you for sharing this information.
In topic 2_a the first figure that shows signal structure is misleading because it incorrectly shows many code chips per cycle. The code is much slower than the carrier frequency; i.e. there are many cycles of carrier per code chip.
FYI, some of the links have been moved since I put this together.
- Survey Marks and Datasheets
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.ngs.noaa.gov%2Fdatasheets%2F&h=ATPlJxj0jUBI1TAt_SbA9G3bmtYw0M_K9AyXgvYfXIzg1n-xQ5N4AmfDVG-tTklDDdnVLRq_yvai8g7Ag0q2asnfugJfx-1hljsu5yjNtRWrT-0AAZFQh0meiWzHwytu_nNH_CJ0yYIUx_WzzCdWzkB_prP2Ag&apos ;"> https://www.ngs.noaa.gov/datasheets/FGCS Standards and Specifications
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.fgdc.gov%2Fstandards%2Fprojects%2Faccuracy%2Fpart1%2Fchapter1&h=ATNO1jwd-GD8Kg5vrsUN8yKoPLDqk01K6lMNdSG23eJG8hLbkxEYe3hid-znyrb5n3sv1zy_9ucw30HEueFlGmxtvD6uu8w9oy_H1M3y4LbncIQAo1N1uPu07EXA7zaAGvLmOl_UW50Bdm1OyFmuGucuuuwblg&apos ;"> https://www.fgdc.gov/sta.../projects/accuracy/part1/chapter1
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.fgdc.gov%2Fstandards%2Fprojects%2Faccuracy%2Fpart2%2Fchapter2&h=ATO2y88Px_LaZKg9pnAWeAlkeMBHMnBUgjfPCNh8DGEQPqqR7NQzX5dS1yvRmbCNHB10iR3FBnp1Q780ZrMSNKc5HgPRpqv7ebrddSO1HqCbNflAdClz6hZ-JPp_tPZKVnoir1axlRlRq7m99Q0EjyO_sQSIAQ&apos ;"> https://www.fgdc.gov/sta.../projects/accuracy/part2/chapter2
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.fgdc.gov%2Fstandards%2Fprojects%2Faccuracy%2Fpart3%2Fchapter3&h=ATMZXkgxmfcTaC97QJnHhAiWGWUL6rc77kCTo04GXnUuatJakhAMGmV_Z1guk-C7TUe7ALwdTvAYILNK8LNNOZ3PCS56jr_Ewd5v5otaS1v6NAKOoRH2ox_2shd1KaEnPEJRW2QMcWMCJ_jUffIBut4tXnP4LQ&apos ;"> https://www.fgdc.gov/sta.../projects/accuracy/part3/chapter3Global Positioning System (GPS) Survey Specifications ? SEPTEMBER 2006
https://l.facebook.com/l.php?u=http%3A%2F%2Fwww.dot.ca.gov%2Fhq%2Frow%2Flandsurveys%2FSurveysManual%2F06_Surveys.pdf&h=ATMoXr1HCrO9N6QN1XwKXcH2A1UBa5OBRMH6w4niUVcNGb0HUI6zE-l8WIiDqRCjioskMsG8qlsD99jOvKoVGCTtJ2Sf2rLa38EQr5wBXlHtxZ2vnbcd-AMqnOL4S2SLHAJVl1SOBUpM4P--0GDDfT17nx6eoA&apos ;"> http://www.dot.ca.gov/.../SurveysManual/06_Surveys.pdf
Thomas Taylor, post: 438853, member: 12899 wrote: FYI, some of the links have been moved since I put this together.
FYI, those links are broken and lead to Facebook.
