curves having wrong...
curves having wrong heights in carlson survpc
2 Users
hawko
(@hawko)
when using survpc recently had a problem where curves were coming out as 2d polylines as apposed to 3d polylines despite them being exported with heights.?ÿ any ideas on how to fix this?
Posted : June 1, 2022 5:22 pm
ladd-nelson
(@ladd-nelson)
Several questions:
  1. How were the polylines created? Via a Feature Code and the Field-to-Finish routine or manually via the Draw -- Polyline command? If the former, what are the properties of that code (e.g. Point, 2D Polyline or 3D Polyline)?
  2. How does the polyline "list" inside of SurvPC?
  3. What version of SurvPC are you using?
The proper solution will likely be determined by the process used to create the polyline.
Posted : June 5, 2022 8:31 am
hawko
(@hawko)
@ladd-nelson 1. they were created in civil 3d and exported to survpc. not sure on further details since I didn't create them
2. it lists as a 2d polyline
3. version 6.12
Posted : June 5, 2022 4:16 pm
ladd-nelson
(@ladd-nelson)
@hawko Please see my reply at this thread.?ÿ
Posted : June 5, 2022 6:45 pm
