Make Trimble Access...
Make Trimble Access stop asking for "Base Data"??
5 Users
i-ben-havin
(@i-ben-havin)
An employee (neither of us are real experienced with Trimble Access), tried to set up an R10 to use as an internet base, but gave up without success. Now, I am having trouble just using either our R10 or R12 as a network rover on the Florida network.
Whenever I try to start measuring with the receiver by clicking on "Measure", then "Select Survey Style", the Error dialog shows "Could not start base data" error message.
What has to be done to make Access stop trying to start the base? The base I need to use is on the Florida Permanent Reference Network, and it is already running. There is nothing for me to start. I have tried everything I could think of.
Any help is greatly appreciated.?ÿ
Posted : June 1, 2022 1:18 pm
i-ben-havin
(@i-ben-havin)
Solved!!
Posted : June 1, 2022 1:45 pm
jitterboogie
(@jitterboogie)
@i-ben-havin?ÿ
Telepathy is a powerful medium isn't it...
Posted : June 1, 2022 10:36 pm
lurker
(@lurker)
Tell me what the solution was. I might run into the same problem someday.
Posted : June 2, 2022 9:24 am
i-ben-havin
(@i-ben-havin)
@lurker Ensure what you are using for internet access has not lost internet connection. All the while I was looking for something complicated, because someone had changed a lot of the usual settings, and I was going over all the changes to be sure they were back where they needed to be. Never thought to look for internet still being connected because it had never lost connection before. Kind of humbles you.?ÿ
Posted : June 2, 2022 3:24 pm
lurker
(@lurker)
Thank you. Every little quirk we can gather will help us avoid losing a bunch of time trying to figure out what is happening.
Posted : June 2, 2022 4:47 pm
Norm
 Norm
(@norm)
The first crew I was on had zero batteries, zero cables, zero data collectors, zero electronics. Even a dip needle. Simpler times. Not easier or as productive necessarily. But there are those days when I wonder.?ÿ
Posted : June 2, 2022 5:43 pm
Flippin dji go 4 app wonƒ??t let you fly the drone unless you are logged in which requires internet, a problem when you are way out in the middle of no where. You can fly without internet if you are already logged in. We had used that iPad before but it had been awhile so maybe it requires a new login,not sure. Extremely stupid and aggravating that software engineers think there is internet everywhere in the entire world. Eventually I found weak signal but then was given the wrong password (he forgot he changed it I guess). So I call my boss to look for the password in a text file but he couldnƒ??t find it. I found it in 2 minutes back at the hotel (using the vpn).
itƒ??s just extremely stupid to have to be able to login to an internet service in order to fly an aircraft. We are getting a new, bigger one that doesnƒ??t have any of that login silliness.
Posted : June 3, 2022 5:12 pm
