Ashtech/Thales Z-MA...
Ashtech/Thales Z-MAX Zxtreme rollover fix
11 Users
robots
(@robots)
Hi,
same as with trimble 4000 https://surveyorconnect.com/community/gnss-geodesy/trimble-4000sse-week-rollover-problem-fixed/
I have also been playing with Ashtech/Thales Z-MAX receiver and Ashtech Zxtreme receiver.
For Zxtreme i have fixed firmware version: ZE21
For ZMAX i have fixed firmware version: ZA00MD05
Is there interest for such firmware? Let me know 🙂
For these receivers if the internal battery goes bad they don't loose firmware, only the user settings and time is lost. I personally replaced ZXtreme internal battery for CR2032 battery holder and put cr2032 battery inside. This way there is no more soldering and removing of the board from the case. Board holds very well in place by heat spreading compound foam stuff, i had to heat the board little to get it loose.
Posted : November 2, 2020 5:57 am
Mark Indzeris
(@mark-indzeris)
I am still using Zxtreme's for OPUS and static work.?ÿ I am currently using winteq to correct the gps week for OPUS and am definitely interested in a potential fix.?ÿ
Posted : November 10, 2020 3:44 pm
larry-scott
(@larry-scott)
Any hope for Z-XII and ZSurveyor?
I have a spare Z-XII for experimentation. (I have others, but wouldnƒ??t want to risk bricking them.)?ÿ
Posted : November 10, 2020 7:18 pm
robots
(@robots)
Problem.is that I dont have access to Zsurveyor and Zxii firmware
Posted : November 10, 2020 9:23 pm
hi-staker
(@hi-staker)
The real question is: Why? There are so many better choices to use. New base/rover pairs with GLONASS can be had for +/-10k. Retire those clunky boat anchors!
Posted : November 11, 2020 7:50 pm
larry-scott
(@larry-scott)
@hi-staker
Because I have 3 Z-receivers and matched geodetic antennae. And they work as well as the day they were delivered, (with the only exception of W/R). Newer is faster, but not more accurate. And itƒ??s pure love. I use T2 and HP3805 for the same reason.?ÿ
They are obsolete, but they are not worn out, and theyƒ??re not financed.?ÿ
Posted : November 11, 2020 8:30 pm
hi-staker
(@hi-staker)
@larry-scott
Even if you can get the firmware updated, how are you going to get around the FCC 12.5 narrowbanding? As far as I can remember from my Ashtech days, none of their receivers could be narrowbanded.
Posted : November 11, 2020 9:44 pm
Posted by: @hi-staker
Not an issue for static work.?ÿ No communication between receivers!
Posted : November 11, 2020 10:34 pm
robots
(@robots)
@hi-staker
If radio is problem use external one. I have modified zmax radio module and put Lora-base DUT inside. Works very well.
Posted : November 12, 2020 12:29 am
robots
(@robots)
BTW, why hijack thread about Z receiver firmware with hate speech ? if you don't like those receivers or think that they are old bad heavy just .... start your own thread. This behavior should be moderated!
Posted : November 12, 2020 1:08 am
Posted by: @larry-scott
I hear that sound, loud and clear!
Posted : November 12, 2020 7:03 am
larry-scott
(@larry-scott)
@nate-the-surveyor
i did have to replace the internal cmos batteries. Which was kind of hard, but the original batts lasted well over 10 yrs.
And the download software is win10 USB compatible. The ZSurveyor writes to compact flash. So why not? In my neck of the woods 1 hr, 1.5 hr and opus is just fine. Phase differential fixed integer baseline is still near perfect at 0.2 miles or 100 miles. Opus is just an option.
So, the RF section and 701008 antenna are stellar. Oh boohoo theyƒ??re only 12 channel L1/L2 Z mode. $35K ea in 1998 was real money.?ÿ
Posted : November 12, 2020 8:06 am
I've got a fully functional set of legacy e units. I've replaced internal keep alive Batts. With 35 watt base batt, and old PDL 3500 rover radio.
I aught to sell em.?ÿ
I've also got some old 8 channel l1 locus units.
Yes, old. But, they were fine gear!
After running a javad.... It's hard to think of going back.
But, I hate to see these gather dust.
Posted : November 12, 2020 8:35 am
Posted : November 12, 2020 8:36 am
larry-scott
(@larry-scott)
@nate-the-surveyor
ZSurveyor, high grade antenna, and opus impresses me to no end. Setting and controlling 30 targets over a county wide project in 1980 was a big deal.?ÿ
Posted : November 12, 2020 8:55 am
larry-scott
(@larry-scott)
@nate-the-surveyor
i was scoping out some target locations today. Nice day for it. And Trimble ScoutMaster perfectly up for the task.
when boots up on screen:
copyright Trimble 1995
Posted : November 13, 2020 7:36 pm
hi-staker
(@hi-staker)
@robots
Seriously?! Hate speech? C'mon man, that's taking it a bit far. Life's way too short to get your panties in a wad about such trivial nonsense.
Posted : November 15, 2020 10:10 pm
robots
(@robots)
@hi-staker call it whatever you want, still off from original topic
Maybe people just want working paperweight, but working. Not with date 20 years off.
Posted : November 16, 2020 1:25 am
larry-scott
(@larry-scott)
@robots
they work great. The W/R error is a quick fix in post, not a deal breaker. A firmware upgrade for W/R would be nice, and completely optional.?ÿ
but theyƒ??re no more a paper weight than a T2.?ÿ
Posted : November 16, 2020 5:53 am
whewison
(@whewison)
Hi,
I would be very interested in an tweaked firmware for the Z-Max receivers. We're still using about a dozen of them - having purchased them all new many years ago. I have been going through our inventory over the last week or two, re-furbishing battery modules, replacing CMOS batteries, and ensuring they're all on the most up-to-date firmware. We have a work-around for the rollover in data processing, but it would (of course) be preferable to avoid the hassle.
In fact, we also have four of the Z-Xtreme receivers too, so I'd be keen to see if we can drag them kicking and screaming into the current age.
I appreciate the interest in maintaining these old workhorses!
Cheers!
Posted : April 13, 2021 3:04 am
