Question regarding computing azimuths from interior angles
kjac
 kjac
(@kjac)
I'm working my way through the "surveyor reference manual" workbook (which is a little lacking in explanations) and I'm somewhat stumped on one of the questions. I assume that it wants me to find the back azimuth and then work from there adding interior angles etc... however it goes from adding 180° to later subtracting 180°. It seems like they are adding in extra steps with the 180° bit, but I'm not entirely sure what to make of it. I've included the question from the book and answer key below if anyone cares to help me out.
Posted : June 13, 2014 7:37 pm
duane-frymire
(@duane-frymire)
You can add the 180 if you want to. They are just getting the back azimuth, and in the instance of subtracting it keeps it between 0 and 360 without the additional step of subtracting 360 from a higher number (as they did in other parts). They are just trying to spin you around and see if you still make it back to the road.
Posted : June 13, 2014 7:48 pm
jacob-wall
(@jacob-wall)
For each leg you could apply a MOD 360 rule (modular) that may help clear it up for you. By that I mean if the calculated azimuth is greater than 360° then you subtract 360°, and if the azimuth is less than 0° then you add 360°. This only helps if I have understood your confusion correctly! Modular arithmetic
Posted : June 13, 2014 8:07 pm
jaro
 jaro
(@jaro)
That looks like an Andrew Harbin survey problem.
James
Posted : June 14, 2014 7:43 am
