Which cup will get ...
Which cup will get filled first?
10 Users
(@flga-2-2-2-2-2-2-2-2)
engineering pz
Posted : June 22, 2023 3:30 pm
(@jerry-attrick)
6
JA, PLS, SoCal
Posted : June 22, 2023 3:33 pm
(@antcrook)
Three
Posted : June 22, 2023 5:19 pm
GaryG
(@gary_g)
Three
Posted : June 22, 2023 6:25 pm
6 STAYS EMPTY AS IT IS BLOCKED.  SAME FOR 4 & 5.
If the liquid is highly viscous, the answer could be 1.
Posted : June 22, 2023 7:08 pm
You need to look very closely at the lines, as not all pipes are open. Thus the answer is 3.
Posted : June 22, 2023 7:11 pm
Trick question.  The tap is not connected to a supply line.
Posted : June 22, 2023 7:15 pm
GaryG
(@gary_g)
@holy-cow I assumed it was with the drop of liquid showing.
Posted : June 23, 2023 2:31 am
(@prince0)
Not all of the pipes are open, so you need to look very closely at the lines. So, the response is 3.
Posted : June 23, 2023 4:03 am
Also could be 1 if the temperature of the pipes is below freezing.
Posted : June 23, 2023 7:38 am
3 is the only one that can fill
Posted : June 23, 2023 8:29 am
Using ambient temperature water, the answer is three.
Other answers are possible depending on the termperature and viscosity of the liquid.
If the pipe system is at a very cold condition and the liquid very hot,  cup #1 would shatter and none would be filled.
Posted : June 23, 2023 10:12 am
(@lurker)
The ambient temperature of Mars or Mercury?
Posted : June 23, 2023 10:24 am
