Historic Surveys, a...
Historic Surveys, are boundary lines unmovable?
21 Users
(@louella)
Active Member Registered
My home was built in 1900, I own 2 parcels, 8 lots in a township. My subdivision was platted in 1890. My home was built according to plat survey. In 1906 a surveyor placed a set point in township.?ÿ This monument has been changed, and point has been moved. Over a century of survey records in our township have documented countless surveyors, re- establishing corners to what they perceive to be accurate, with movement being over 12 feet. Monuments have been lost, destroyed, or moved. I recently hired a surveyor to mark my boundary corners. As corners were marked, it was clear that original boundary lines were now moved, some distance, over 10 feet. Current boundary lines as marked, go through my septic and 2 buildings, with City ROW now possessing. I now have boundary lines going through my neighbors septic, and heat pump. My neighbors now have boundary lines in the middle of?ÿ City street. My surveyor has told me that property lines move, and I must accept this. The City has commenced to hire an independent surveyor. My question is: if my home/barn/ buildings were built according to the original survey plat, and subsequent surveys have moved and reestablished Monuments, can my original boundary lines from original survey be legal?
Edit: City is Oakville Wa., Gray's Harbor County, Fitzgerald's Addition.?ÿ
Posted : 15/02/2023 7:44 pm
The poster's profile indicates Washington. For many issues the state or even city will affect the responses.
In general once a boundary is marked and the adjoining parties accept it by acting based on that boundary, it should not move.
When corner monuments get disturbed or destroyed, surveyors need to gather available evidence to replace them, and it may not be possible to get them back in the exact same spot. The evidence may include measured distances from the nearest found reliable monuments, occupation, and other facts.
There are surveyors who place too much reliance on the theoretical numbers for one or a few lots instead of giving weight to what has been accepted by the adjoining owners around the neighborhood. If all your lines are shifted in the same direction such as to cross multiple occupations like your and neighbors'septic, this may be the case here,
There's often more to the story than someone puts in their first post, so we don't know what additional circumstances may be involved in a given case.
If you feel it is wrong and important enough, you may need to get another local surveyor for another opinion.
Posted : 15/02/2023 8:22 pm
 Norm
(@norm)
Noble Member Registered
Absolutely
Even if true it doesn't apply in the situation described. If all else fails, estoppel can be a legal remedy. If the neighbors like where the boundaries are, they can agree to that first and foremost. Surveyors have no authority to place lines where they never were.
Posted : 16/02/2023 7:19 am
Illustrious Member Registered
Boundary lines do not move, but with evidence of their location being repeatedly lost and restored their true location can, sometimes, be difficult to recover.
The location of improvements is frequently evidence of the location of boundary lines, but it isn't proof. It is not at all unusual for things to be built in ignorance of, or indifference to, the location of lines.
Long term unchallenged occupation of land not within that land described in your deed may result in certain unwritten rights to continue to do so. Your surveyor should be able to discuss these matters with you, but if you wish to claim title to such land you will probably need to get an attorney involved.
Posted : 16/02/2023 9:25 am
(@fairbanksls)
Prominent Member Registered
You don’t have to accept anything based solely on the opinion of a surveyor.
Posted : 16/02/2023 12:49 pm
(@chris-bouffard)
Property lines, if laid out in the original subdivision, do not move, especially 10 or 12 feet.  Markers can be placed in the wrong spot or even moved by a landowner who doesn't like where they are.
Given the age of the original survey that you note and the fact that the recent surveyor notes property lines going through long standing improvements, that surveyor should have noticed the 10' + shift and paused to figure out what was going on instead of just relying on numbers that were potentially measured from an incorrect starting point.
The platted subdivision of 1890 documents the original intent.  Evidence that existed in 1890 may no longer exist but it is our job as surveyors to follow in the footsteps of the original surveyor.  Being told that lines move and that's something that you should accept is the wrong answer, especially with long standing lines of occupation not in harmony his/her most recent determination.
Posted : 16/02/2023 1:22 pm
(@rover83)
The lines as run on the ground for the original survey are to hold, absent any modification by actions of landowners, the public, etc. as mentioned above.
If the original monument from which your subdivision was laid out was moved from its original position, or was destroyed and reset in a different location, it can indeed be difficult to reconstruct where that original position was.
As a general rule, however, if the position of that monument has been lost and/or cannot be reestablished with certainty, it cannot control any more. If I'm not certain of that original position, I'm not going to be making a guess and then calculating an entire subdivision from it. This known as "slapping the math on the ground".
This is especially a problem when applying such a solution clearly conflicts with long-established lines of possession. When no other evidence can be applied with better certainty, those possession lines are often the best available evidence.
Again, I could be wrong here, and there might be more to this than your surveyor is telling you. But screwing up entire subdivisions by simply running math from a theoretical point is poor practice.
"Occupation, especially if long continued, often affords very satisfactory evidence of the original boundary when no other is attainable; and the surveyor should inquire when it originated, how, and why the lines were then located as they were, and whether a claim of title has always accompanied the possession, and give all the facts due force as evidence.
Unfortunately, it is known that surveyors sometimes, in supposed obedience to the State statute, disregard all evidences of occupation and claim of title and plunge whole neighborhoods into quarrels and litigation by assuming to "establish" corners at points with which the previous occupation cannot harmonize."
Posted : 16/02/2023 2:56 pm
 Jed
(@jed)
Estimable Member Registered
How much did you pay for your survey?
You get what you pay for.
Posted : 16/02/2023 3:10 pm
Famed Member Registered
This illustrates why sometimes the cheapest survey is far and away the most expensive to fix.
Posted : 16/02/2023 3:33 pm
(@murphy)
I performed a survey similar to what you've described and ended up deciding that there was no better evidence than the house.  I had parol evidence from multiple disinterested parties stating the house had been the first built on the block and second in the subdivision all during the same year the plat was recorded.  I said to myself, "Self, what's the difference between a witness monument and a house that was said to have been built to the plat while the laths were still wet?.  Can an improvement be a quasi-monument?  What better evidence exists as to the intent of the original surveyor or subdivider?  Is it more or less likely that a given house is built over the boundary line?"  In my particular situation, the neighbors also independently noted that the old man who built the house used to joke about the unbuilt street being three feet off his front doorstep.
Ask one of the surveyors why a house built in 1900 is not better evidence of the original boundary location than a corner set in 1906.  Ask more about when the ROW was formerly established and why it would push closer to you and not the opposite direction.  Washington may have strict rules about ROWs that supersede any boundaries established through long occupation.  If it becomes necessary to get a lawyer, ask it what the consequences are ($$$) if you do nothing and force others to bring a lawsuit against you for refusing to accept the updated boundary.
Posted : 17/02/2023 5:48 am
I have a feeling the unknown surveyor was being sarcastic about accepting moving boundaries.
Posted : 17/02/2023 6:58 am
 Norm
(@norm)
Absolutely agree. Retracement requires finding the evidence nearest the time of the original conveyance when the original survey lines were known and that evidence generally isn't on paper. I might add that far too often the evidence that disagrees with the paper is viewed as evidence of unwritten rights when its actually evidence of the first survey.
"Nothing is better understood than that few of our early plats will stand the test of a careful and accurate survey without disclosing errors. This is as true of the government surveys as of any others, and if all the lines were now subject to correction on new surveys, the confusion of lines and titles that would follow would cause consternation in many communities. Indeed the mischiefs that must follow would be simply incalculable, and the visitation of the surveyor might well be set down as a great public calamity." Diehl v. Zanger, 39 Mich 601, 605
Posted : 17/02/2023 7:01 am
 Norm
(@norm)
@dave-karoly We can only hope so. Went back and reread the post a couple times. It's just sad the results of a survey can cause the question to be asked. We may not know all the details or what was said but the results as explained say a lot.
Posted : 17/02/2023 7:02 am
 jph
(@jph)
As usual, there're probably some missing details and some things lost in translation.
Boundary lines don't move or change, other than water boundaries, which move with the meanderings.
Generally, it's the measurements which change with each survey.  12 feet seems like more than a measurement change/difference, so there's another explanation out there.  Your surveyor, or another local surveyor should be able to explain it better than how you related above.
Posted : 17/02/2023 7:12 am
(@jered-mcgrath-pls)
@louella, As you can see by many of the comments, you have us all intrigued with your situation. Land Surveying has a lot of General Rules and regulations and Standards that we follow, but there is a lot of "It depends" and case-by-case details that need to be reviewed along with the evidence weighed to formulate an opinion that focuses more on a specific solution to your problem. It would be great if you could provide more details like a location for a start. If in Washington, as your profile indicates, there are a lot of Publicly available records we can look up to get a better understanding of your local situation. Best regards.
Posted : 17/02/2023 8:19 am
Page 1 / 3
Share:
