Our firm could use someone with field experience (2 years?) or some other relevant survey experience that can use Civil 3D to draft surveys. The plan would be to move forward over time into a project surveyor role and hopefully obtain a PLS.
Currently, our project surveyors are drafting their own surveys, but I would like for each of them to reduce that in order to expand their responsibilities.?ÿ
If you are on the Kitsap Peninsula (or want to travel there each day for work), and are at all interested, please message me and I will buy you lunch.
God you have?ÿ no idea how badly I wish I lived closer.?ÿ ?ÿSounds like the chance of a lifetime!
Good luck, it's a difficult find.?ÿ
Why would they have to go to an office???ÿ Just a thought.?ÿ?ÿ
I'm available for remote work for sure if you're interested,?ÿ moving to that location would be possible especially if its a good fit.
In the parlance of the tech savvy millennial?ÿ crowd...
HMU???? !
I looked into that as well...?ÿ lots of upside.
if the person doesn't work out, it's not a huge change.
the person isn't in the area, so not a competitive threat
limit risk of file copy theft
if the person is in a different time zone, you could have your drafting done while you sleep and check it over coffee!
alas, I didn't pull the trigger on that, and just worked until I burned out.?ÿ?ÿ
@andy-j?ÿ
As an employee,?ÿ you'd be bound to all the customarily expected responsibilities and obligations to your employer, which usually means all the same nondisclosure binding and enforceable policies as if you're there in person.?ÿ
The part I'm guessing is the hardest part is getting to work together for the indoctrination,?ÿ on boarding,assisting, and such, furthermore also being able to hit the field occasionally when needed. That's hard as hell to do remotely. And expensive unless you're doing 3 week rotations like I did when I worked collecting geophysical data etc.
Wow.?ÿ That's a personally attractive offer <shiftyeyeslookingbackandforth>.?ÿ I've got close family on Lopez Island.
They do not, but I have found that mentoring from a distance is not my strong suite. Perhaps this is uncommon to have this weakness, but it does exist in me.?ÿ?ÿ
If a person was a fully functional project surveyor/survey drafter (understands surfaces, field conditions, boundary, etc), then fully remote would be great. I am working under the assumption I will not find that in this market, but I might be wrong.
The issue is what they would expect from me. If redlines and constructive criticism is enough, then remote would work.?ÿ
In fact, half of our current office staff work happens remotely. One is a PLS that works 100% remote. The other is a project surveyor (not a PLS) that comes in once a week. The once a week makes a difference, IMHO, but is essentially not needed for the retired PLS.
I just struggle with remote training, so the limitation is completely mine.
It is. Just do it.
Management at the large firm where I worked could never grasp this, but in solo practice I find doing my own drafting is so much more efficient.
The trick is to move a few project surveyors into more senior roles to handle the big-picture stuff, but not hollow out the experience and efficiency already present having the project surveyor intimately involved in their own work. PMs shouldn't be involved in the day-to-day, boots-on-the-ground work of surveying. I'd go so far as to say that they shouldn't be in responsible charge and stamping the final product 99% of the time. Let the manager manage, and let the surveyor survey.
We are pretty much a corporate shop, and PMs rarely have the time or the ability to actually act as project surveyors, but corporate doesn't want project surveyors in the mix because it costs $$$. As soon as someone gets their PLS they get pressured to become a PM so they can bring in work, because the only metric is how much we are selling. So many PMs could care less about mentorship and training - their bonuses aren't dependent on it - so we end up with PMs that are neither technically competent nor good at managing personnel, and often mediocre surveyors to boot. Our efficiency is far worse than the field-to-finish project surveyor model because of it. I'm going to stop there. End of rant.
