Zenith 25 issues
2 Users
razorbackfan4life
(@razorbackfan4life)
Iƒ??m hoping someone here could help me out.
I have a zenith 25(geo max) unit. ?ÿWe have been using it for the past couple years with little to no problems.
We are currently working two jobs, and I have operated this unit on both sites with no issues. ?ÿToday I went back to the previous job, which I havenƒ??t been on in a little over a week. ?ÿKeep in mind the geo max was operating fine yesterday. ?ÿWell this morning I went to set everything up. ?ÿ My base loaded up fine, and then I proceeded to load my rover up after. ?ÿ
Every time I try to monitor and skyplot, with my rover, it freezes within the first 30 percent or so and drops all satellites and connection to the base.
To make sure I wasnƒ??t having a base issue I ran monitor skyplot with it and it was showing me Autonomous at 100%, which is good. ?ÿEverything looked right on that end.
Just to check and see if the rover was truly jacked up I took my unit over to the other job site and it loaded right up. ?ÿ My rover was speaking to my base and I was 100% fixed. ?ÿ This job site is about 3 miles away.?ÿ
I feel like it has to be some kind of interference, but Iƒ??m not a 100% sure.?ÿ
Any tips? ?ÿThanks
Posted : February 26, 2019 11:59 am
va-ls-2867
(@va-ls-2867)
Local interference sounds like the most logical culprit.
Posted : February 26, 2019 12:06 pm
razorbackfan4life
That was it. ?ÿSpoke to a representative that guided me along. ?ÿSomeone near me was using the same data transfer. ?ÿI just had to change the mode. ?ÿ Thanks?ÿ
Posted : February 26, 2019 2:14 pm
