I got a call from my survey professor asking when tapes graduated in decimal feet were first used in surveying.?ÿ He is preparing an article and has not been able to find anything on why decimal feet became the standard instead of feet and inches.
Nearly all of the mineral surveys I have seen in Colorado (from 1868) were measured in feet and tenths of feet.?ÿ This is likely because the mining laws give limits of mining claims in feet.?ÿ In looking at the history of the engineer's chain (100 feet in length with 100 links), it was likely adopted for construction projects like railroads and canals.
All I could come up with was that surveyors adopted the engineer's chain as an alternative of the Gunter's chain because there wasn't an architect's chain.?ÿ ??ÿ
I think any survey map (or description) would be vary rare, hence I would venture to say... always decimal feet.
(I do remember one guy trying to use a 100' carpenters tape, what a CF!)
https://amhistory.si.edu/surveying/type.cfm?typeid=4
http://blogs.toolbarn.com/2014/06/tbt-the-history-of-the-measuring-tape/
Very interesting articles.
I would add that one should check with he US Bureau of Standards for when they first started calibrating steel tapes.
The tapes I used were only calibrated in feet, mark on lead solder, with the tenths of a foot only marked at the zero end. Most were 101' long with the tenths being added below the zero. Only a few were ever marked in tenths from zero to one, had to pause and think when using that one. The hundreths between the tenths of a foot marks was eyeballed (interpolated). The front chainman would hold a foot mark on the destination, call it out,?ÿand the rear chainman called out the hundreths.
When you coiled a tape you held the end foot in the left hand and the right hand would almost naturally stretch back to a five foot lead blob, bring it forward and do over, the grab the loop at either side and twist the right hand and the loop size was halved.
Measuring a long line with chaining pins was good initial training in meaning a measurement to get a truer value.
I had to do an as built back in the early 80's on a navigation lock wall (long and narrow). We had to locate all of the objects on the wall like railings, mooring pins, ladder recesses, etc. This was in the pre-data collector days, so it was all done with a steel tape. The engineers wanted stationing in feet and decimal feet, and offsets in inches. After struggling to try and use two different tapes we decided to do it all in feet and decimal feet and then convert the offsets manually afterward.?ÿ
I am about 3/4 of the way through a book called "Measuring America"?ÿ
Very interesting, explains how we almost went metric at the beginning, but clashes of personalities got in the way.?ÿ
The former was called an "add" chain, the latter a "cut" chain.
