What would you do? Reject a whole township line?
19 Users
ridge
(@ridge)
Working on a survey and need section corners that are in highway ROW (not defined). County section corners have been put in about 15 years ago by a ƒ??dependent resurveyƒ?. A plat was filed by a private surveyor paid for by the county. It's mostly proportion but doesn't actually cite finding any hard evidence, they decided to use a few points and proportioned from there, maybe a third of the township.
So I'm working in the township to the west side of the township line which was resurveyed and finished in 1914 by GLO. Tracted all along the township line (east tier of sections). So I find lots of tract corners which are steel post with brass caps. This leads me back to the township line and so far I've found three hard corners along the township line and now that I'm tuned in will probably find more and probably all the corners could be put back using the proper procedures from real corner evidence.
Yesterday I dug up one of the original township corners ƒ?? 3 inch post and cap under a gravel road intersection. So basically my evidence will show that ever section corner along the township line in the highway ROW is set in error. Since lots of other corners were set by proportion from these corners, probably the corners in a third of the township can be shown to be improperly placed.
Welcome to my world, I been telling the county for 15 years they needed to do things different and put a real licensed and qualified surveyor back into the county surveyor position.?ÿ All I ever get back is there is no money for that, not since 1957. The corners were set from grant money from the state and feds. My county is a welfare county, its either money from elsewhere or none at all. They wasted it on the lowest bidder and contracting by a non qualified person to even know if they would get what they were supposed to. It still goes on like this to this very day.
What would you do? Maybe just file a survey with my findings and let it roll from there. Sort of a reject every section corner along a township line survey. This won't get me any more work. County will probably stop even talking to me. If they see real professional work they think you are from Mars or something because its so different from what they are accustomed to.
Whatever!
Posted : June 13, 2018 10:20 am
How much reliance by landowners on the flaky corners?
Posted : June 13, 2018 10:41 am
ridge
(@ridge)
Most landowners in the county are wise to flaky surveying and don't bother to move their fences.?ÿ Some build new fences to new survey lines.?ÿ It takes 20 years under Utah law to establish a boundary unless an agreement before then can be shown.
Property lines get fixed by reliance of landowners.?ÿ Section corners never move if they can be shown where they were originally placed.
Posted : June 13, 2018 10:49 am
You are not rejecting a Township Line, you are in fact finding and perpetuating the actual/original Township Line, which by reason of what you have uncovered has never been lost. I would indicate "found Original(or dated) Township monuments and "Found monuments erroneously set by said County at later date".?ÿ
You have a certain obligation as a registered surveyor, getting future county work is not listed as an obligation to anyone.
Posted : June 13, 2018 10:50 am
aliquot
(@aliquot)
You need to reject the corners as control for the boundaries between any two land owners that you can't make a very strong case of reliance or agreement for. Stick to you guns and do it right. Recognize that some boundaries may use the county positions because of agreements, but that does not make them the PLSS corners.?ÿ
If you are surveying against any federal boundaries it probably is a good idea to talk to BLM.?ÿ?ÿ
Posted : June 13, 2018 11:02 am
Leon,
Paul nailed the core issue. would caution you on a few finer points.
Those erroneous monuments are not PLSS Corners but they are evidence for other purposes. Work with the County Surveyor to educate them on the difference.?ÿ
Also be careful setting any newly proportioned corners. Minor problems in the original proportion are not cause to reject them. The courts are loathe to accept one proportion over another...
Posted : June 13, 2018 11:28 am
@Mr. LRDay
First off, I respect you.
Doing the right thing, means the same thing as the oath that the glo made chainmen swear to.
Look up that oath.
You are in good company.
Nate
Posted : June 13, 2018 11:36 am
jitterboogie
(@jitterboogie)
Ugh.?ÿ Sounds like where I currently live.?ÿ "Can't afford it.... Too Much Money......Blah Blah...."?ÿ They just built a new $8.7M building they didn't need, and yet the surveying and recording continues to stay in the "way we've always done it BS....
At least I can claim Cartoon Status.?ÿ Park County and South Park get memorialized weekly with the Cartoon, "South Park" with all the value of the real life?ÿ circumstances that spawned the whole idea in the first place.
Take the higher road, in the end it's always worth it.
Good Luck.
Posted : June 13, 2018 11:37 am
Make. HUGE standing bill to the county, maybe 1.2 million.
Publish it everywhere.
"For fixing county's mess".
Ya never know... You may eventually collect it.
Posted : June 13, 2018 11:47 am
Sounds like a text book case of when to record a Record of Survey detailing what was found and how you interpreted those facts on the ground. That will at least put other surveyors on notice down the road. If you don't it's likely the situation will continue to unravel and become more and more convoluted as time rolls on.
Just my .02'
Posted : June 13, 2018 11:55 am
jamesf1
(@jamesf1)
"What would you do?"
Mr. Day,
The first thing I would do is contact the other surveyor and explain the issue. What I would do after that depends on what he does...
Posted : June 13, 2018 11:59 am
ridge
(@ridge)
I thought the rule for proportioning was between the nearest original corners.?ÿ Don't have that here.?ÿ Proportioning from the nearest guessed corners.?ÿ Looks to me the county corners are from about 10 to 25 feet from where they should be.?ÿ This is SOP here.
Posted : June 13, 2018 12:00 pm
If you find an original monument and the "new" monument is over there then the original absolutely controls.
On missing original monuments set by the GLO then you have better evidence of where it probably was originally located than the "new" monument over there BUT property owners can expect finality in boundary location.?ÿ So this situation is a little more difficult.?ÿ If no one has used the "new" monument then you can reject it.?ÿ Otherwise be careful.
On corners not set by the GLO and set for the first time by the "questionable" survey, if they were accepted in good faith by the affected property owner I would think long and hard before rejecting them.?ÿ On the other hand if they fly in the face of older evidence such as ancient fence corners then they are more reject-able.
Property owners do have the right to reject a questionable survey as long as they do it in a timely manner and there is no substantial detrimental reliance.
My way of looking at it is the monument is either the corner or it isn't.?ÿ There is no other class of corners that aren't the corner but they are the corner.?ÿ The point of acquiescence is that it identifies (or not) the corner you are looking for.?ÿ So if the questionable monument was set for a 1/16th corner and it has been established as such then my personal feelings on the reprobateness of the monument don't matter.
Posted : June 13, 2018 12:09 pm
Leon,
It is great to know there ?ÿare still some "real" surveyors on the job. ?ÿWhat I keep running into are people who email Hub Tack or the equivalent State agency to locate section corner data they have on file and then incorrectly assume they have applied adequate due diligence. ?ÿOne must research all local survey files or they are not applying due diligence. ?ÿThere are far too many corners filed, and then relied upon by others, that are simply the result of slipshod procedures by untrained button pushers who look like heroes when they reduce costs on a specific job. ?ÿI can think of an example of that not far from here where the true corner is in the center of a county road but requires digging through about 15 inches of very hard material. ?ÿThe most recent corner record available suggests a bar set by a "never met a proration I didn't like" button pusher that used to be about 60 feet away in a corn field (set level with surface). ?ÿ"Used to be" referring to a bent piece of rebar found more or less horizontal about 20 feet away from the location cited on the "toilet paper-worthy" corner record. ?ÿOne must do thorough research in order to do professional work. ?ÿIt also helps if the poorly trained technician understands that different surveying standards and practices were used for the Government surveys on opposite sides of certain lines. ?ÿFor example, some center corners were set at the crossing of quarter section lines while others had the center set at the midpoint of a quarter section line that was to be run parallel to the east section line. ?ÿIt depends on the official instructions in the year of the Government survey for that particular section. ?ÿOne size does not fit all.
Posted : June 13, 2018 2:28 pm
Sounds like a mess, good luck Leon.
This doesn't happen to be a standard line does it?
Posted : June 13, 2018 3:43 pm
ridge
(@ridge)
Posted by: Jim in AZ
Mr. Day,
Probably do that.?ÿ If the past forecasts the future don't expect him to want to change anything.
Posted : June 14, 2018 6:14 am
Norm
 Norm
(@norm)
Posted by: LRDay
If you mean original corner monuments there would be no proportioning in this state because there are none.?ÿ I like that idea!
Posted : June 14, 2018 8:00 pm
ridge
(@ridge)
Posted by: linebender
Posted by: LRDay
More correctly proportion from the nearest existent corners.?ÿ So you don't need the original stone/post/pits/mounds but you should have good evidence back to where the original corner was.
In this case I have 1914 brass caps by the GLO, some along the range line and on the west side tract corners 40 or less chains distant.?ÿ None of this "evidence" is referenced in the prior proportion.
Now reliance.?ÿ There may be reliance on the corners, but not for 20 years as the corners are newer than that.?ÿ But who is held to reliance.?ÿ If a couple of landowners rely on a proportioned corner does than mean the corner controls for all other landowners that haven't yet relied on the corner??ÿ Is a landowner required to accept a corner that others have but they haven't?
I suppose I'm just venting a bit.?ÿ The whole valley is messed up.?ÿ About the only way to really settle where a boundary is located is current agreements between landowners (or validation of long term acquiescence).?ÿ That's where the PLSS abuse and neglect has gotten us.?ÿ ?ÿI know I'm not alone here.
Posted : June 15, 2018 9:08 am
Proportioning is acceptable as evidence of the original corner location if that is all there is.?ÿ Of course, it is only valid between the nearest original corners.?ÿ If the erroneous survey only set paper corners then you know what it is useful for.?ÿ If it set monuments then that is more troublesome; if the monuments are buried an no knows they are out there then they can be ignored.?ÿ If they have been accepted then their effect is probably local.?ÿ But all boundary is local anyway.
I believe all of the boundary doctrines grew out of the need to prove original evidence, they are not equitable procedures as has been suggested in the past.?ÿ Other than the entire body of real property law evolved in equity, not common law.?ÿ For example, paper deed transfers were not legally recognized before the Statute of Frauds except in equity.?ÿ Livery of Seisin was absolutely required for the Law Courts to recognize the title transfer.
Posted : June 15, 2018 9:15 am
ridge
(@ridge)
Posted by: Dave Karoly
County section corner caps were set by a contractor along 5 of 6 miles of range line.
I'm not sure a buried corner can be ignored.?ÿ I've dug up lots of them, even stones that didn't set off a detector.?ÿ It's not that hard to buzz up a steel post with brass cap.?ÿ The first thing that needs to be done to find a corner is to go look for it.
If a GLO survey of record exists with details of the corner monuments, doesn't that serve notice that the corners are out there and should be hunted for??ÿ If covered up with some soil are they no longer valid??ÿ Maybe a landowner has an excuse but not surveyors.?ÿ A landowner can hire a surveyor.
Posted : June 15, 2018 10:21 am
