Wall thickness caliper
7 Users
totalsurv
(@totalsurv)
I am looking for a tool to measure wall thickness on the inside and outside of buildings around window and door openings. I was thinking of some sort of caliper that can measure around door frames etc. I currently use a tape but was looking for something for measuring around architraves and the like and giving a direct thickness of wall without deducting frame sizes etc. Any recommendations?
Posted : February 5, 2016 2:25 pm
norm-larson
(@norm-larson)
I am aware of the thickness gauges that machinist's use and Googled them and came up with this http://www.carbatec.co.nz/digital-thickness-gauge_c21153 . It goes to 150mm so on a thick wall it might not be possible to get past the trim
Posted : February 5, 2016 2:31 pm
vern
 vern
(@vern)
Make your own.
A matched pair of [ shaped pieces with a carefully placed pivot point so that both ends measure the same. You could flip them for inside measurements if needed.
Posted : February 5, 2016 3:16 pm
It'd be easy enough to fab a scissor-like device out of aluminum flat bar. Make it symmetrical around the pivot so you don't have to deal with multipliers, add a spring to keep it snug against the wall and you can tape the thickness with your free hand.
Edit: Vern beat me to it with the same idea.
Posted : February 5, 2016 3:17 pm
I'm with Jim on this.
But not being sure what end use would be put to I'd measure several places and make a note of any discrepancies.
If it does vary then say so and state this clearly.
I was once asked to measure the underside of concrete beams for fitting an outrigged walkway.
I had a set of giant callipers used in bridge work. The bridge was by the sea and concrete a bit spalted in places, plus the boxing used was flooring and finish good enough for out of site construction.
The beams varied and I said they varied in thickness from x to xx mm. Did not impress and my credentials to measure was questioned. o.O
Posted : February 5, 2016 3:26 pm
roadhand
(@roadhand)
I am sure that I could do a little arithmetic and make something like http://www.rockler.com/sure-footreg-f-style-clamps&apos ;">This F Clamp into a measuring tool.
Posted : February 5, 2016 6:20 pm
Am I the only carpenter in the pack?
http://www.garrettwade.com/lumber-thickness-gauge.html&apos ;">lumber calipers
Posted : February 5, 2016 8:26 pm
Those look pretty slick, though they might be a bit small for some applications, particularly where the trim is thick and/or deep. Still, for that price they'd be worth a try.
Posted : February 5, 2016 8:43 pm
totalsurv
(@totalsurv)
Thanks for all the suggestions. I have found this I think it may be the ideal solution http://g-nestle.de/en/product/wall-caliper/#tab-2&apos ;">Wall caliper
Posted : February 6, 2016 3:02 am
totalsurv
(@totalsurv)
One of my employees put together this. It's a bit clunky but should do the job.
Posted : February 27, 2016 2:46 pm
