Hi
I would like to utilise survce ability to perform gps when using with a robotic total station.
Looking to put a gps card (via the cf slot) in my tsc2. Having trouble finding information on the net. Would anyone have any advice as to what type i need?
Do i then need to cut through the tsc2 dust cap because the antenna will stick out as i don't want to leave the other cf slot exposed to weather?
Thanks
I have one, never really worked well. It is a HOLUX GR-271. There is an "extension" cap that will replace the other cap.
http://www.holux.com/JCore/en/products/products_content.jsp?pno=226
Hi John
Thanks for the reply. In what way didn't it work well? Did you have trouble getting the tsc2 to recognize it?
Thanks
It was a long time ago, probably around 2006. If I recall it often had trouble recognizing the card.
