Trimble T02 files to Rinex
DeralOfLawton
(@deral-of-lawton)
I have two small Trimble .T02 files that I need converted to Rinex but my software will not read these. Can anyone give me a bit of help?
Posted : February 10, 2011 5:32 am
christ-lambrecht
(@christ-lambrecht)
Hi Deral,
don't know what software you use but this should do it
Trimble Convert to Rinex Utility
http://www.trimble.com/trimblerinex_ts.asp
you'll also need the Trimble configuration Utility too, same link.
Release notes
good luck,
Chr.
Posted : February 10, 2011 5:53 am
DeralOfLawton
(@deral-of-lawton)
I checked that out earlier but it seems to update Trimble products to use this utility and it does not appear to be a stand alone. Am I wrong?
Posted : February 10, 2011 5:57 am
christ-lambrecht
(@christ-lambrecht)
Oops ...
don't know, I have of course TGO installed, and never used the utillity before.
Let me know if you get stuck and want them converted,
chr.
Posted : February 10, 2011 6:08 am
DeralOfLawton
(@deral-of-lawton)
I downloaded and installed both without any problems but when I run the converter is starts up then crashes. I think it needs to run inside the TGO suite of products. I was going to send you the files but the email on this site does not allow attachments it seems.
Posted : February 10, 2011 6:32 am
christ-lambrecht
(@christ-lambrecht)
Deral,
sent at
c[dot]lambrecht[AT]arcadisbelgium[dot]be
I'll see if I can convert them here
I have output to rinex 2.11 en 2.0 available
c.
Posted : February 10, 2011 7:11 am
DeralOfLawton
(@deral-of-lawton)
Coming your way Christof. Thanks a million.
Posted : February 10, 2011 7:17 am
jaro
 jaro
(@jaro)
Deral,
Mine works fine and I don't have TGO
I use the Data Transfer Utility to download the .T01 file from the receiver to my computer. The utility converts it to a .DAT file in the process.
I then use the Convert To Rinex program to convert the .DAT file to rinex .10o file and send it in. When you select the file in "Convert to Rinex" it will show some of the heading data on the screen. You have to hit the square button with a down arrow and RNX below it to actually convert it.
That's the limit of my knowledge on the subject.
James
Posted : February 10, 2011 9:36 am
John1Minor2
(@john1minor2)
Deral
I'll be in the field most of the day today, thursday, but I can try to help this afternoon or evening if Christof's solution doesn't work out for you. just email the files to [email protected]
John1Minor2
Posted : February 10, 2011 10:01 am
DeralOfLawton
(@deral-of-lawton)
Thanks so much Christof. The files have some problems it seems on the operator end. (field crews and methodology)...
I sure appreciate your help.
Posted : February 10, 2011 10:07 am
Joe M
(@joe-m)
http://facility.unavco.org/software/download_transfer/trimble/trimble.html
Posted : February 10, 2011 5:17 pm
Tom Bryant
(@tom-bryant)
It IS a stand alone utility....does not need TGO or TBC to run...
Posted : February 10, 2011 7:06 pm
