Topsurv offset problem
1 Users
djames
(@djames)
I know some of you guys use Topsurv .
I just found a bug with Topsurv 8.1 if staking line offsets it will switch from offset left to right or vice versa if you go in and out of the Station screen with out your knowledge . The stake out screen really does not give you an idea if your are left or right so you might not catch it as I did not until I had work in the ground . Could have been bad .
Also watch using the design offset routine . If you put a design elevation in on the fly it will override even if you advance through the points . you must exit back to the to the previous screen or clear it manually . It should clear once you advance the point .
Posted : June 22, 2011 5:48 pm
