TOPCON Tesla RTK
Spec1441
(@spec1441)
Hello Surveyor Connect community.
I have recently purchased a set of topcon GR5 receivers and Tesla combo for an undergraduate surveying course. I have no problems with initial setup and things are working out well so far.
The only thing I can notice is that when I am setting up my base, I have issues (aka no luck) getting a GREEN "FIXED" box,or even a yellow float. However, it allows me to setup my base, then connect to my rover, where I can easily get FIXED and have no problems roving.
Anyone else have this base setup experience?
Thank you,
Spencer
Posted : September 26, 2013 9:17 am
david-livingstone
(@david-livingstone)
I'm not familiar with your equipment but when you set up your base it is a single stand alone unit so it will not have a fixed solution.
Posted : September 26, 2013 9:42 am
Vince
(@vince)
Yup. The base will always be autonomous in a simple base/rover setup. On our Topcon Hiper V's, the fixed (green), float(yellow), autonomous(red) indicator lights always show red on the base.
Posted : September 26, 2013 10:30 am
JerryS
(@jerrys)
Amen or ditto to the two comments above.
The base in such a setup is always either working off the autonomous position it gets from the satellite data or a Geodetic starting position you supply.
In either, or any other case for that matter,the base in such a setup will never have a fixed solution status in the sense that the rover does.
So if you are seeing "Fixed" on the rover, that is as good as it gets.
Posted : September 26, 2013 10:34 am
