Topcon Hiper+ TopSURV FC-200
I am running a Topcon Hiper+ rover on a local RTK network here in Indiana. We are using TopSURV on a FC-200 data collector. It connects via Bluetooth to a Verizon cell phone with a data plan.
All of a sudden lately after I connect to the internet via the #777 through the cell phone, then as usual when I select Survey --> Topo --> Config Modem which is supposed to connect to either the INCORS or the TOPNEXT local network, it simply will not connect to either network.
I have reached out to our local dealer here in Indianapolis, but they often seem to be pretty busy, so I am reaching out to you.
I wonder if I have some setting wrong?
Posted : May 26, 2013 8:00 am
(@mikefondren)
Had the same issue and it was a FIRM update that was needed, recommend you check that.
Let me know if you can't find help, even though I'm way out west I have an excellent guy that helps me at RDO
Posted : May 26, 2013 10:22 am
Wow, thanks a lot Mike.
Your first login and post.
I am honored.
Thank you.
Posted : May 26, 2013 10:44 am
My subordinate employee slash partner never uses foul language with one exception...
dealing with the FC200 which according to him is the most troublesome piece of equipment he has ever had to deal with.
Posted : May 26, 2013 10:47 am
(@sir-veysalot)
Been there...done that
Posted : May 26, 2013 3:04 pm
(@spledeus)
i thought the fc-200 would be better than the fc-100
we now have a fc-2500
Posted : May 27, 2013 8:25 pm
(@jd-juelson)
Toasted a FC150, replaced it with a FC200 (about threw it off the dock), rented a FC2500, purchased a Fc2600. Still collecting dust but should be in the field today.
Had the same problem with the 200, firm ware was the issue.
-JD-
Posted : May 28, 2013 7:24 am
Well I am shipping this off to Hayes tomorrow.
Troy was good enough to recommend that I send this off to Hayes.
I sure do appreciate a good stand up man.
Posted : May 28, 2013 1:31 pm
