Topcon GPT-8203 RC Quicklock and TDS
dmgonsal
(@dmgonsal)
Does anyone know if TDS Survey Pro Robotic support communication with the RC-2 with bluetooth. I know it works for the regular RC-2, but I have the RC-2 with bluetooth and I cannot seem to get my recon running Survey Pro Robotic v.4.5.3 to communicate with my RC-2. Does anyone know if this works? If so can you let me know your settings within Survey Pro. I am also running this with the Bantam type radios.
Posted : February 22, 2012 11:28 pm
Steve Burkholder
(@steve-burkholder)
I have the same exact setup only difference is I have a ranger and satel radios . mine works fine feel free to give me a call and I'll pull out the ranger and go through the settings [msg][/msg]
Posted : February 23, 2012 7:07 am
Mack Chete
(@mack-chete)
Yes i have that setup with ver 4.7.1. in tds settings are
Brand = topcon
Model GPT-8000 remote
Serial port com1
baud 9600
parity none
then under instrument settings in TDS
remote tab
radio = Generic (Bantam)
RC-2 = Y-cable
at the bottom of that screen
Note: RC-2 dip switch 3:on
the settings in the gun are
cable
9600
D8 S1
None
ext.
hope this helps.
Posted : February 23, 2012 7:12 am
dmgonsal
(@dmgonsal)
Clarify - RC-2RWn - a Bluetooth RC
> remote tab
> RC-2 = Y-cable
So Mark,
You use "RC-2=Y-cable", even though you aren't using the Y-cable? Just to be clear, I have the RC-2RWn, which is a bluetooth version of the RC-2, which doesn't require the Y-cable. At least in theory it doesn't, I can't get it to work that way though...
Posted : February 23, 2012 7:27 am
I think you will find that the recon is the problem. I had trouble with bluetooth and the recon. using the rc2 as a radio is much slower than a regular radio, get some hayes instrument bantams, they work good out to about 1300 feet
Posted : February 25, 2012 12:55 pm
