Tolerance Settings Carlson BRx7 Rover
field-dog
(@field-dog)
I use the following tolerance settings for my Carlson BRx7 GPS rover:
Min. Solution Type: Fixed
Hrms Tolerance: 0.097 ft
Vrms Tolerance: 0.197 ft
Latency Tolerance: 3.0 s
Max Baseline Length: 15.5 mi
PDOP Tolerance: 3.500
What tolerance settings do you use and why?
Posted : January 10, 2026 6:44 am
Topic Tags
TNT
 TNT
(@tnt)
I am on the same model (different seller) I do not recall seeing max baseline but everything is the same except I have PDOP set at 4.
Which is ridiculous because anything over 2 might as well be float.
EDIT: Which deep old woods, not near a boundary, I have done. You just set Float tolerances as tight as you can to still get a fix. (when not topoing). And I am using a base setup not RTK.
This post was modified 9 months ago 2 times by TNT
Posted : January 11, 2026 10:22 pm
Young-Surveyor
(@young-surveyor-2)
My Carlson BRx7 has the same setting....
Should it be set to 0.05 for Hsdv and 0.07 for Vsdv?
Posted : May 18, 2026 7:31 am
field-dog
(@field-dog)
Posted by: @young-surveyor-2
I don't know, but I found something on reddit.com.
Gps data collection tolerances. : r/Surveying
Posted : May 18, 2026 4:49 pm
