Testing Topcon Hiper Battery Capacity
8 Users
big-al
(@big-al)
I've got a pair of Topcon Hiper Pro GNSS receivers. Haven't used them much in the field yet, but have a job coming up and would like to be sure the batteries will hold up for a full day in the field. At the moment, my data collector is being repaired, and I'm wondering if I can test battery capacity by simply turning the units on and seeing how long they last? Are all communication functions enabled upon turning the units on (i.e. drawing full power) or must they be turned on by data collector or through PC connection? Any help would be appreciated. Also, any suggestions on when you would replace batteries, ie 6 hrs, 8 hrs, etc? Thanks.
Posted : October 19, 2012 7:53 am
DeralOfLawton
(@deral-of-lawton)
Use the free PCCDU and check the batteries at full charge then after running them 8 hours. Make sure you have the antenna's on. I'll find my spreadsheet and let you know what a new battery should look like and also a four year old battery.
Posted : October 19, 2012 8:04 am
jimmy-cleveland
(@jimmy-cleveland)
I would suggest that you just turn them on, and check them regularly and see how long they will run. That is the "simple" way to see how long they will run.
I have a pair of Hiper Lites, and they have internal batteries, that are not hot swappable. Basically, when they run low, or die, you just have to plug them back up to the chargers.
I do know that you can look at the charge of the batteries thru PC-CDU, but I don't think that you can tell how long they will actually run. I know, and year or so ago, my base unit would only run about an hour or so when it was really cold. I just replaced the batteries earlier this year, and have been pleased with the results. I did it myself, and it cost about $60.
Hope this helps.
Posted : October 19, 2012 8:07 am
big-al
(@big-al)
Deral,
Thanks. That's perfect. I've got that utility on the laptop, and I'll get the receiver connected and do some testing. Exactly what I was looking for thanks.
Posted : October 19, 2012 11:26 am
Remember temperature affects their charge, and that at cold temps, (20-30°) you could run for 4-6 hrs, when at 85 you could run all day.
Ya might as well buy some batts.
Posted : October 19, 2012 12:13 pm
DeralOfLawton
(@deral-of-lawton)
I'm still searching. I know it's around here somewhere. There was a marked difference in the drop off of voltage after one hour on the old batteries vs the new batteries. I logged several sets over the years and the trend was undeniable.
Of course temps impact the duration but using the utility proved to me whether it was time to recell/replace based on years and cycles of usage.
Posted : October 19, 2012 12:58 pm
big-al
(@big-al)
According to the appendix of the Topcon Hiper Pro Manual, the internal batteries are Lithium Ion (4000 mAh, 7.4 V) and there are 2 of them in each receiver.
Also, on page 2-7, the following detailed explanation of full batteries is provided:
And, though this graph is not applicable to the specific battery of the Topcon Hiper Pro, it nonetheless suggests the characteristics of a lithium ion battery:
Posted : October 19, 2012 3:49 pm
The Pseudo Ranger
(@the-pseudo-ranger)
Not to hijack this thread, but I've been thinking about purchasing a Hiper Pro Base unit for use as a network rover, and I was also wondering if the Radio on the BASE unit is on and transmitting, even when the unit is being used as a RTN rover. Is there a way to disable the radio, since it seems like unnecessary wear and tear to keep the radio on when it's not really sending useful data.
Anyway, I think that's what the OP is getting at. Does the radio turn off when it's not being used?
Edit: Now that I look at the posts above closer, that quote from above say "If the internal radio is turned off ...", so it does appear to be possible to turn the radio off. Anyone know how to do it?
Posted : October 19, 2012 7:41 pm
victorstone
(@victorstone)
I agree replace the batteries if your concerned, it was easier then you would think.
Posted : October 19, 2012 7:53 pm
big-al
(@big-al)
Confusing information in the Hiper Pro Manual, in the Appendix, page A-3.
Under the section entitled "Power" it describes the operating time as follows:
With TX mode ON (1W) - 6 hours
With RX mode ON - TBD
With Radio in Standby Mode - 13 hours
With Radio OFF - 16 hours
Whereas at page 2-7, the same manual states that with a full charge the internal batteries should power the GPS receiver, Bluetooth, and the Satel radio Modem transmitting data at 1W for 11 hours.
Why the difference?
Posted : October 19, 2012 8:57 pm
big-al
(@big-al)
Page 1-12 (table 1-2) of the Hiper Pro Manual suggests that the radio modem can be off, in receiver mode (either recognizing the transmitting receiver or not), in transmitting mode, or in command mode.
I don't know how to turn the radio modem off, but it looks like it can be done.
Posted : October 19, 2012 9:08 pm
big-al
(@big-al)
Again, at the appendix at A-3, the power consumption of the receiver is listed as 10 Watts, in TX (transmitting) mode (1W).
I believe that the amperage draw (A) can be calculated from P=V*A, where P is power in watts, V is voltage, and A is amperage. The battery voltage is 7.4. Therefore, if the receiver draws 10 watts in TX mode, divide by 7.4 volts, and the amperage is 1.35 amps.
Since there are two internal batteries, each having a capacity of 4000 mAh, or 4 amp hours, the total capacity is 8 amp hours. 8 amp hours divided by 1.35 amps, is about 6 hours total run time. That agrees with the specification in the appendix.
What is closer to what you all have actually experienced in the field with the base in TX mode - 6 hours or 11 hours?
Posted : October 19, 2012 9:17 pm
dms330
(@dms330)
I believe that when we use one Hiper unit as a network rover our TDS Ranger settings automatically turn the radio off as it is not needed, thereby saving battery power. One way to turn the radio back on is to reboot the unit.
I believe there are ways to turn the radios on and off other than I have described above but I am unfamiliar with the locations of those settings.
Licensed Land Surveyor
Posted : October 20, 2012 5:49 pm
big-al
(@big-al)
Well I ran a test today with the base, using the PCCDU utility to monitor internàl battery voltages. Beginning with a full charge, and with the receiver in transmitting mode, I got a run time of 8 hours and 20 minutes. I wouldn't expect to get as much on a cold day outside. But pretty good I think.
A few notes on battery voltage- full charge appears to be about 8.0 volts, and power cutout (end) appears to be about 6.6 volts.
Posted : October 20, 2012 6:21 pm
sjc1989
(@sjc1989)
I have hiper pros running on older batteries. I get 12hrs+ at 80deg, 8hrs at 50deg, 5hrs at 30deg and 3hrs at 10deg.
Perfect for me, I only last about 3hrs at 10deg myself.
Steve
Posted : October 20, 2012 8:52 pm
big-al
(@big-al)
Thanks, Steve. It was an unusually warm day here in MA, and my testing was done partly inside and partly out. I'd say average temp was 70 degrees. Sounds like your getting more life on your older batteries than I would. I've ordered some replacement batteries in any case.
Posted : October 20, 2012 9:14 pm
big-al
(@big-al)
Based on both Steve and Nate's posts, I'm thinking that the Topcon manual for the Hiper Pro is correct when it states a minimum of 11 hours on a fully charged battery (assuming room temp), and that the reference to 6 hours is incorrect.
Posted : October 20, 2012 9:21 pm
big-al
(@big-al)
UNAVCO has a list of GNSS receivers that they've used over the years. While the Hiper Pro is not on that list, the only receivers which use 10 or more watts of electricity are the older big box receivers like the Trimble 4000, the Ashtech Z-12, etc. If I had to hazard a guess for what the Hiper Pro would consume based on that list, I'd guess 4 watts. Does anyone know of a source for more data on the electrical characteristics of the Hiper Pro?
Posted : October 20, 2012 9:35 pm
