Tried to process vectors in TBC from Sokkia Stratus receivers and had no luck. The vectors are always float 1-5 m off or so.
One vector is 13km obs time 1:09 and second one 4.8 km obs time 1:07 so no problems here.
My friends have a lot of control points tied in with Stratus receivers but can not use them in TBC (TGO is ok, current backadated RINEXes work good.)
I was wondering if anyone here had the same problem. This is also good to know before buying the receivers from eBay if you plan to process their data in TBC.
Can't comment on TBC (assume that is Trimble) but I have no trouble with Spectrum Survey and I think as L1 only you can have that as a Stratus owner.
I have 3 units and they are great.
Use them a lot for static control supplementing RTK and Total Station work.
they have Spectrum Survey and it works fine. They have also a mix of different receivers, trimble R3s, promarks and Staratuses... Since TBC has a nicer interface and more flexible, easy to add NGS calibrations easier to remove portions of bad signal etc. they wanted to process everything in TBC but unfortunately ... Stratus RINEXes are not very friendly to it
I like the units as well, nice compact last forewer on two batteries.
If you would like to play with Stratus RINEX files I put them here
