TBC 2.81 update
5 Users
I have not been able to successfully download and update from TBC 2.80 to TBC 2.81.
On my desktop, it downloads OK, but the install stops with a CRC failure (i.e. one of the files appears to the unpacking program to be corrupted, the CRC value doesn't check). I have downloaded both the update and the full install, same problem. And I turned off anti-virus temporarily.
On my laptop, the update download gets to the end (774 Mb), and stops.
Anyone have any success getting this update to install? I have a good internet connection, never have had any problem with corrupted files or download failures.
Posted : December 5, 2012 6:52 am
Dave Ingram
(@dave-ingram)
We got it to load and install OK. But you have to be patient at that 774 mb point. I think our download took 10 minutes (or more - maybe it was a half hour) when it said there was 1 second to go.
Also, make sure the box in the lower left is checked to download file before install.
Good luck.
Posted : December 5, 2012 7:22 am
I downloaded and installed without incident. Win7 64-bit, if it matters.
Posted : December 5, 2012 8:58 am
ridge
(@ridge)
I did it last night. Once the download is complete then just start the executable file. It didn't start itself for me.
I been working in TBC lately. It's a better program than TGO by far. It's just getting through the learning curve as with any new software.
Posted : December 5, 2012 9:15 am
Rob O'Malley
(@rob-omalley-2-2-2-2-2-2)
It might be our internet speed here at work (dedicated T2) but it took my PC about 3 hours from download to complete install.
Yes it is slow and hangs up, but it does finally make it through.
Posted : December 5, 2012 9:39 am
Dave Ingram
(@dave-ingram)
When I did the download, the 774 meg point was reached in about 20 minutes at which point it said 1 second to go. That is when it took that very long time to go the final second. Even worse than college basketball.
Posted : December 5, 2012 10:30 am
I am known to have little patience, maybe that is the problem...
I will give it another try.
I have FIOS, on the speed test (www.speedtest.net) I get 40 Mbps down and 30 Mbps up, although I am subscribed to 75 down/35 up. Like I said, I don't think it has anything to do with my connection, I often download very large files with no problem.
Posted : December 5, 2012 1:01 pm
