Puzzle for the day-?ÿ I'm trying to figure out what the division are on this steel tape: (the lower tape in this picture)
This is from an Ebay auction, at https://www.ebay.com/itm/Unusual-New-Steel-Tape-on-Wood-Reel-Not-Feet-Not-Links-Not-Sure-What-it-is/353306589101
The major subdivision is decimal 1.18ft, or 14 and 3/16th inches, (14.1875 in)...or?ÿ in metric, 36cm ? - but it doesn't seem to close to any known American, Spanish or European measurement (even the various flavors of Texas and Mexican Varas.) ?ÿ
?ÿI thought I would be able to google my way to figuring out what this steel tape is sub-divided into/what the graduations are for.. but have had no success.?ÿ If this was marked in 1/5ths of a unit, then 180cm might be the larger division- K&E sold some tapes marked in 1/5th of a Vara.- but everything I've found puts the Vara at around 33 inches...?ÿ?ÿ A?ÿ 6ft fathom divided into 5ths is close, (14.4 decimal inches).. but about 1/4inch longer than this division.
I've corresponded with the seller, he's been in Alaska, Montana and South Dakota- so could have been picked up from those areas.
I'm not looking to purchase it, just curious as to what obscure and forgotten corner of the measurement arena this came from that I've missed.
N.D.
cubits? ?????ÿ
Nope, not quite long enough.
Furlongs per fortnight
Check the seller's other items, lots of interesting things being offered.
GB
We're missing some information the seller could have supplied.?ÿ Is there one major division with minor divisions? If so, how many small ones? Is it a cut or add tape??ÿ Is 50 the last division??ÿ What is an accurate measurement of the overall length?
And how does that work??ÿ
If stretched along a slope of one particular angle, it could read horizontal feet, but is that useful??ÿ?ÿ And it would be an excessive slope for most civil work.
@bill93?ÿ It shows 1 minor division halfway between the major divisions.?ÿ The only numerical markings in the picture were 4|9 and 5|0, not sure if that was the end or beginning- have asked the seller for more info.
@rj-schneider?ÿ I'm not personally familiar with a "slope tape", but from the book "Forestry Handbook, 2nd Ed, by Karl Wenger, c1984"?ÿ a slope tape has a trailing section of tape that has graduations according to the secant of the angle of slope, which allows one to calculate the actual true horizontal distance from a tape that was measured along a slope...?ÿ but the rest of the tape still had normal 1foot=12in graduations.
See pg 1091 in this book as shown on Google Books:?ÿ
https://www.google.com/books/edition/Forestry_Handbook/YVteNzkhHYoC?hl=en&gbpv=1&bsq=clinometer
The distance you give between marks (14.1875 inches) is very close to one-fifth of a Swiss "faden" or Swiss "klafter".
A bulk liquid storage tank dipping tape. It doesn't matter what the divisions are, as long as they are constant (for a uniform tank), and you have the tape-measure-to-volume-conversion-factor for a particular tank.
Alternatively a nautical depth gauge (fathoms, etc).
If it doesn't matter what the divisions are, I doubt anyone would go to the trouble of setting up an unusual spacing rather than using feet or meters. And a steel tape kept on a reel isn't going to hang straight for dipping.
A fathom is 6 feet.
That's a close correspondence, but a) why would anyone put the numbers on a tape?ÿ with units of 1/5 of the "standard" unit
And b) that's anachronistic. Meters would have been in use before that kind of tape was made (although not as much as my facetious suggestion of cubits.)
If you divided a nautical mile by 5280, would that be a nautical foot??ÿ Just asking for a friend. ?????ÿ
@rj-schneider?ÿ So you have to attach the tape to the theodolite and somehow look down its length to make sure you're holding it on the angle??ÿ This sounds like it might be more hassle than it's worth.
The only references Google finds for me that seem relevant say that in 1963 someone tried to define a nautical foot as 1/6000 of a nautical mile, but I don't think it caught on. See:
https://www.jstor.org/stable/26169605?seq=1
It is proposed that units of length called nautical spans, chains and feet??and defined respectively to be 60, 1/60 and?ÿ1/6,000 nautical miles in length??be adopted internationally for use in weather-service and aeronautical operations
@bill93?ÿ?ÿyou said "And a steel tape kept on a reel isn't going to hang straight for dipping"
Well I guess you never heard of a plumb bob? Go to ebay and type in dipping tape. You just might learn something.
JOHN NOLTON
@bill93?ÿ There is nothing wrong with Mr Lindell's statement... It is correct.?ÿ
Its close to 1/2 of a?ÿarshin ;?ÿBut we still don't know what it is. I myself would like a better measurement between several marks on that tape,
say with a digital caliper to the 0.001 inch.
JOHN NOLTON
